Arduino Mega 2560 RFID Serial Communication
2 posts / 0 new
I have an RFID reader:
Something like same above along with ITEAD TFT shield & GSM Modem. The RFID reader has RS-232 port as well as GND,TX and 5V pins. I am using Arduino Mega 2560 Board. I have connected the TX,GND of RFID reader to RX3 pin 15 / GND (pin) of Arduino. Note I am supplying 12 V to RFID via a adapter.
Note the ITEAD TFT shield consumes TX0, RX0 pins - so I cannot make use of RX0 and TX0 pins. Though I have not written the code for GSM modem.
Now while running the below program I am getting junk output both in my TFT display as well as serila monitor:
#define __AVR__
#include <UTFT.h>
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
UTFT myGLCD(ITDB24,59,58,57,56);
String myString = "";
void setup() {
   Serial3.begin(9600);
   myGLCD.InitLCD();
   myGLCD.clrScr();
void loop() {
  myGLCD.setFont(BigFont);
  if (Serial3.available()) {
    int inByte = Serial3.read();
     myString += String(inByte);
    if(myString.length() == 10)
      myGLCD.print(myString, CENTER, 0);
TFT Screen output:
1310494848
Serial Monitor Output- non printable junk character.
The value is incorrect I am pretty sure, what wrong am I doing?
I found that ITEAD shield is sending or rather using RX0/TX0 pins very frequently - some data is going thru.
BTW what is the functionality of http://arduino.cc/en/Tutorial/So... ?
Well in all other words "How can I use 3 different Serial I/Os individually at same time without disturbing any other I/O?"
I was finally able to solve the issue. The issue is that String Object in Arduino does not supports '+' operator (I was assuming to concat the values). As such my string variable was always empty and nothing got printed in TFT.
The below code works fine and I am able to integrate RFID reader at Serial port 3 along with displaying of data in ITEAD TFT screen :
#define __AVR__
#include <UTFT.h>
char myString[15];
int ind = 0;
void setup() {
   myGLCD.InitLCD();
   myGLCD.clrScr();
void loop() {
     if(inByte >= 33 && inByte <= 127)
       myString[ind++] = char(inByte);
    if(ind >= 10)
      myString[ind] = '\0';
      myGLCD.print( (char *)myString,CENTER, 0);
      memset(myString, 0 , 15);
      ind = 0;
