which microcontroler have more lifeTime
7 posts / 0 new
hi
for first sorry formy bad english
I need make a cooling system for my car engine
I want controll fans with a havy duty microcontroller
the fans are 3 mods
off . lowSpwwd . highSpeed
I want use adc to controll the fans
my problem is :
1 car cockpit have many magnetic nois and bad wather
2 car shoud poweroff and start for manytimes in a day
3 and engine cooling system is important I must go to currect way :D
I feel it's one of those, If you have to ask don't do it sort of thing....
But I'm always asking questions and then doing things, so go for it
What you want can be done. It's done all the time.
Make one you think will work.. test it until you know it wont fail.
All designs are tested, more testing make a better product
fans require high power control and isolating the processor.
a power supply with Big inductors, big Capacitors
metal cases
Keith Vasilakes
Firmware engineer
Minnesota
thanks my buddy
I just test it with attiny13
a voltage regulator
and 2 reley
but my microcontroller was destroyed after 3 hourses working
I hear SMDs quality is bether than normals. is true?
so your comment is I should test all types to finding good microcontroller
or all micros are same I must remove nois and chang curciut to get more life
I will try it
thank you
make sure that if you take power from your unit, the system should behave the normal way.
here are some hints.
make 100% sure to have a good ground.
have a reverse diode on the relay coils.
Make sure you have reverse polarity diodes across the coils of your relay, or the spikes will destroy your micro.
Google any motor control relay circuit and you will see the diodes I'm talking about.
Either you had a dud or, far more likely, there is something (or some things) seriously wrong with your design!
Remember that the engine compartment of a car is a very hostile environment for electronic components!
The datasheet gives you the safe operating conditions for the device - exceed any of them, and you are very likely to damage you chip.
ehsan_wwe wrote:
thanks my buddy
a voltage regulator
and 2 reley
I will try it
thank you
It's not the parts you are using, it's how you are using them.
You need to have good protection for your parts as talked about above.
Testing means testing your design, finding the failure and then determining why that failure happened.
the Micro was not bad
SMD would not improve things
Remove noise and improve power supply is the way to fix it
Keith Vasilakes
Firmware engineer
Minnesota
