how to program to sample a sine wave.
9 posts / 0 new
i am new to AVR programing.can anyone tell me how to do the programing,to sample a full wave rectified sine wave of 0-5v and 50 hz into ADC of atmega32.i need some kind of code example,i understood the theory but i can't do the coding in AVR studio 6.thanks in advance.
There are articles in the tutorial forum about using the ADC. Have you read them? What wasn't clear? If you understand how to operate the ADC then what other problems are you having?
What information do you need about the sine wave?
Amplitude?
frequency?
shape?
RMS?
frequency change over time?
Harmonic content?
Depending on how you answer the above the solution can be anything from Rectify and filter it to running an FFT...
Keith Vasilakes
Firmware engineer
Minnesota
In addition to being in the wrong forum, it is also a cross post.
keith v wrote:
What information do you need about the sine wave? ... shape?
Errr... If it is a sine wave, then you know its shape!!
So youre saying it's a perfect sine wave?? no noise? No harmonics? no jitter, wow, flutter?
I'd like to see that
Keith Vasilakes
Firmware engineer
Minnesota
Ashif sent me a PM, maybe to others, also.
I responded that it would be very useful to know how this "sample" information is to be used. For example, if it is zero crossings (for a phase-controlled "dimmer) or frequency measurement, then sampling, in the usual sense is not needed. If it is necessary to determine how good of a sine it is, then many (more than 10 per period) ADC measurements are needed. So, to know what kind of "sampling" is needed, more information about the end use is required.
The post talks about ADC but without the requested information, its not clear that the ADC is even important to use.
Hey guys, this thread is in the wrong forum!
It should be merged with his thread in the mega/tiny forum.
His other thread is now locked, and this one is (now) in the mega/tiny forum.
