How to implement a look up table
18 posts / 0 new
Hi folks,
As per title,
I need to compare the 8 bit value from the potentiometer and match a given output which is not linear. For this i plan to use a look up table, but have no idea how to implement the code to read and output the values.
Could someone shed some light on this, please?
Regards
It's not clear to me what you are asking.  A lookup table is just an array.  y=lookup[x].  But I think you have something else in mind.
Type table lookup avr into google search and be amazed at what a search engine can do. Maybe add some words of your own just for giggles.
static uint16_t lookup[256] = {12, 33, 55, 65, 73, 55, 12, 11, 99, 33, 42 <256 values in this array>};
uint8_t pot;
uint16_t convertedValue;
pot =  = ReadADC();
convertedValue = lookup[pot];
//if your compiler complains about 8 bit indexes you'll have to cast it or disable the warning
convertedValue = lookup[(int)pot];
Keith Vasilakes
Firmware engineer
Minnesota
Or perhaps even better, since it's an avr:
const __flash uint16_t lookup[256] = {12, 33, 55, 65, 73, 55, 12, 11, 99, 33, 42 <256 values in this array>};
(That's 2 underbars before the flash. Don't confuse yourself like I do.)
Yes, thats what I have on mind, this is a new subject and I am starting it from first principles, thats all ;)
keith v, thank you very much for your example, it has helped shed some light!
Torby, I am guessing your approach means that rather than loading the array into the ram, I am reading directly from the flash, am I correct?
Is there any advantage in any of the modes, speed wise?
So far i am just a bit confused with one thing: I need to load 3 values from the lookup table. Say i have LED1, LED2 and LED3 and I wish to implement and RGB output depending on the value of my pot. So I will read one column for GREEN, other for BLUE, and finally one for RED. The values are then copied into a temp variable that I use to set the PWM timers, also from a value from 0 to 255. Assume my pot value is 125, which will give me a predefined color and then I load the value for the 3 tables on position 125.
Is this the right way to set this?
table_1[125] = x;
table_2[125] = y;
table_3[125] = z;
Assuming it is, Would there by a way I could call just one table and somehow read the 3 values (x,y,z) from it at the same time? I need to clarify that the values are not related (for example, if I was to do a three phase wave, I could load just one table and add an offset to get the correct value, but for this application the same trick wont work)
Many Thanks
Your 3 tables are one way to do it, but personally I'd use a single table of a structure holding one R, one G and one B.
typedef struct
  uint8_t r;
  uint8_t g;
  uint8_t b;
} RGB;
const __flash RGB RGB_table[125] = {{ 0,  1,  2},
                                    {10, 20, 30},
                                ...etc...
etc.
To add to kk6gm's example (which is the way I'd do it too). The access to the data is then:
potR =  = ReadADC();
convertedRValue = RGB_table[potR].r;
potG =  = ReadADC();
convertedGValue = RGB_table[potG].g;
etc.
Cliff,
Why would you see fit to reread the ADC for each colour? The OP said he is using a single pot.
Cheers,
Ross
That's probably how I'd do it.
Another alternative would be to use a 2-dimensional array...
Oh I didn't read that bit blush
I guess that depends on whether you want to numerically index the R,G,B values or whether you are just happy to refer to them by name - in which case the AoS is perhaps more documentary.
Which is, in fact, the way Atmel do it in their examples for the QT1 Xplained boards:
const uint8_t PWM_RGB_values[64][3] = {
	{20, 0, 0},
	{20, 0, 0},
	{19, 1, 0},
	{18, 2, 0},
	{17, 3, 0},
	{16, 4, 0},
	{15, 5, 0},
	{14, 6, 0},
	{13, 7, 0},
	{12, 8, 0},
	{11, 9, 0},
 	{10, 10, 0},
Indeed.
Although you could use an enum to "name" the array index values...
This, of course, is all standard software design stuff - nothing specific to microcontrollers.
"Algorithms + Data Structures = Programs" - Niklaus Wirth
http://en.wikipedia.org/wiki/Algorithms_%2B_Data_Structures_%3D_Programs
Reading from flash is slower than reading from sram.
Steve A.
Yes, but how much slower? I will be performing about 10 readings per second, will the reading latency be negligible at this rate?
Completely negligible.
I betcha a search in the datasheet fot 'cycle' might find a sentence that answers the question.
