Confusion on TIFR Flags
18 posts / 0 new
In doc2503 (ATmega32 Datasheet), page 83, the following is stated:
• Bit 1 – OCF0: Output Compare Flag 0
The OCF0 bit is set (one) when a compare match occurs between the Timer/Counter0 and the
data in OCR0 – Output Compare Register0. OCF0 is cleared by hardware when executing the
corresponding interrupt handling vector. Alternatively, OCF0 is cleared by writing a logic one to
the flag. When the I-bit in SREG, OCIE0 (Timer/Counter0 Compare Match Interrupt Enable), and
OCF0 are set (one), the Timer/Counter0 Compare Match Interrupt is executed.
Now, is this a typo or am I missing something? Also, a similar statement is present in the description of Bit 0 of this register as well. Thank you for your concern in advance.
Regards
It's not a typo.  The hardware can set and clear OCF0, as described.  It can also be cleared in software.  This is done with a single write, which is atomic, vs. a RMW, which is not atomic and thus open to a concurrency error.  The hardware could have been designed to take either a 1 or a 0 to clear the flag, but in the industry the use of a 1 for such flag-clearing is pretty much universal, and much more intuitive IMO.
The key thing to take away is that the write is atomic and thus safe.  A RMW cycle could encounter the following error:
MC = main code
HW = hardware compare match
MC: read TIFR
MC: clear OCF0 bit
HW: sets OCF0 bit
MC: writes out (incorrect) cleared OCF0 bit
Now a match has occurred but the flag is not set.  Error!
Thank you kk6gm but what I don't understand is how can a bit is set by writing 1 to it and cleared by again writing 1 to it? Or isn't this what the document states? If so, what am I missing here? Thanks again.
Where does it say that the bit is set by writing a 1 to it?  The compare match generates a signal that causes the flip-flop representing the flag to be set to 1.  Writing a 1 to that bit generates a signal that causes the flip-flop to be set to 0.
It says it in the first bold region of my first post in this thread.
No, it doesn't.  It says "cleared".
See very recent https://www.avrfreaks.net/forum/w...
No, it doesn't say that.  It says that a compare match causes the flag to be set to 1.
Think of a code equivalent of the underlying hardware:
if (compare_match)
  OCF0 = 1;
else if (compare_match_interrupt || (bit_is_written_to_flag && (bit_written == 1)))
  OCF0 = 0;
It's not a simple read-write register, which is likely a source of OP's confusion. It has two separate operations: get a copy of flags, and selectively clear flags (and leave the others alone). The first is mapped to a read, the second to a write. And they just happen to share the same address, since it would be a waste otherwise.
Only an interrupt event can set the flag to 1.
You cannot.
If the flag = 0
then either code
setbit(flag)
or
clrbit(flag)
has no effect
If the flag = 1 (caused by interrupt event)
then
setbit(flag) clears the flag to 0 (you will have to live with this)
clrbit(flag) has no effect
I think it is more clear now. Thanks everybody.
One more thing:
if (compare_match)
  OCF0 = 1;
  OCF0 = 0;
So, when I write 1 to OCF0, what actually happens is OCF0 = 0. Is that true?
You can prove it yourself by writing some test code and running it in the simulator.
Yes.
utku1 wrote:
One more thing:
if (compare_match)
  OCF0 = 1;
  OCF0 = 0;
Yes, the hardware for that register is designed so that writing a 1 sets OCF0 to 0, while writing a 0 has no effect.
OK. Thanks a lot again.
Someone earlier said:
Alternatively, OCF0 is cleared by writing a logic one to the flag.
Oh, wait--that was >>you<< in your original post.  Is there confusion that "cleared" means a 0 value, and "set" is a 1 value?
I guess not. "Cleared" and "set" states of the flag is just as the conventional "cleared" and "set" states of any bit as far as I understood. Only different part is, the flag is cleared by writing a logic 1 to it.
