myAtmel Support Broken
2 posts / 0 new
Can't see a forum where this quite fits?
The 'myAtmel' login page accepted my username & password, but when I clicked on 'Open a New Support Case' or  'View All Cases' or 'Search Knowledge Base' it just gave this:
Cross-post: http://www.at91.com/discussions/...
Now appears fixed - but there really should be a proper contact address on that error page!
