Beginning with arm
2 posts / 0 new
Hello!
I have a SAM3N-EK kit and i want to get starting with arm programming.
I had does some efforts with tutorials and examples about ASF, but all my programs works by little bit of luck! so i want to learn something things about arm programming
and arm architecture.
im using ASF
where can i start from?
i tried with simple led blinking program
but the first matter it was:
whats the difference between IOPORT and GPIO.
and some many things who does not understand.
is there some tutorial which explain those things?
Thanks!
Read the ASF manual:
http://asf.atmel.com/docs/latest...
If you select the "Category" there and set it to "I/O" you will see both GPIO and IOPORT listed. If you pick one of the GPIO selections you will see this:
Hopefully the red underlining I have added to that emphasizes the point?
If you do select IOPOT for SAM3 there then there's a link to "quick start" which gets you here:
That should be a good starting point (the fact that GPIO doesn't have such a "quick start" is another clue to the fact that it is deprecated).
