Can Atmel Studio 6.2 Co-Exist with Visual Studio Express?
4 posts / 0 new
Studio 6.0 Release Note wrote:
Issue #AVRSV-3387:
An incompatibility issue with Visual Studio Express 2008 can make Atmel Studio 6 fail to open and
compile C files. Workaround: Disable Visual Assist using the command "Enable/Disable Visual Assist
X" on the VAssistX menu.
http://www.atmel.com/images/as6i...
Is that just Visual Studio Express 2008, or any version?
There is no mention of this in the Studio 6.2 Release Note - was it fixed? Beta or full?
Are there any other co-existence issues with Atmel Studio 6.2 - Beta or full?
Visual Studio 2010 Express co-exists with Atmel Studio 6.2.1153.  I see no issues.  I don't know what visual assist is though.  I wear glasses which does assist my visual.
P.S.  I had a nasty problem when using Atmel Studio 6.2.beta that went away when I installed 6.2.1153.  Using my JTAGICE2 was an iffy thing.  If it was Tuesday it would work for a couple of minutes.  If it was Wednesday it would work for only a couple of seconds.  It may have been dependent on the phase of the moon.
Help. I can't delete this thing.
This forum software seems to be a blend of WYSIWYG with a little magic.  Now you see your post and now you don't.
