rename solution
5 posts / 0 new
Hi all, I have an as6 solution that uses asf, not sure if that matters, and I want to keep that project and create a new one based on the original with a different name so I can modify it for a different project. Whats the easiest way to do this ? Thanks
I haven't dabbled too deeply but doesn't AS6 have the concept of "templates"? I believe you can export a project as a template then use that to create similar new projects.
As per normal you are on the money cliff :wink:
Export project as a template.
Then import. I imported to user boards.
Then open new project from user boards and set new name and location.
I know this is an old thread, but I just googled the same question and got here!
To answer the specific question of this thread's title, "rename solution" - see: http://technet.microsoft.com/en-...(v=sql.80).aspx
Renaming the Solution within Studio does also change the .atsln file name to match.
Renaming a Project within Studio does also change the .cproj file name to match.
And it also changes the "attribute" name (ie, the .elf output name) to match.
Hmm. Last time I wanted to do that, I created a new project with the name I wanted, then copied the source files from the old folder and used "Add existing item" to add them to the new project.
Without adult supervision.
