I didn't know you could get Ada for AVR
48 posts / 0 new
A little frightening, actually
Without adult supervision.
Look closely and you wil find that Joerg Wunsch is quite deeply involved.
However the port is no longer maintained so it's only available in fairly old versions of the GCC toolchain.
Not.
It's a subset of a complete Ada ecosystem that would exist on a Unix, OS X, or Windows.
  • AVR-Ada - May need some thinking to install but its mailing list looks good. Recent fixes (checked in but not yet packaged) improve the installation.
  • GNAT GPL avr-elf-windows - The 2013 version may be released this summer (note: that did not occur).
Refs.
AVR-Ada, Wiki, Status
[Avr-ada-devel] AvrAda on Windows
Libre
I wonder why you say this. Ada is a fine language, for embedded systems in particular. Much better than C or C++.
The most up-to-date version I know of is found at www.adacore.com/libre
I'm waiting anxiously for the ARM Cortex libre release. They've just released a for-pay version, but it hasn't made it to a libre release yet. When that's available I'll never look back.
Cortex-M?
A Cortex-A (ARMv7): http://packages.debian.org/wheezy/gnat, architecture armhf.
P.S.
Raspberry Pi (ARMv6): http://archive.raspbian.org/raspbian/pool/main/g/gnat-4.6/
gchapman wrote:
Cortex-M?
P.S.
Yes, Cortex M bare board is what I dream of.
Now that you ask the question, I'm not sure if the recent ARM Cortex release includes Cortex M. It would be a terrible omission if it didn't, IMO.
AdaCore added Cortex-M to GNAT.
Ref.
Is Ada ready for mainstream embedded designs? by Bernard Cole (embedded.com; February 19, 2013); search for 'Cortex-M3'.
Ref.
Yes, and I'm waiting for the GPL release.
I come from a "pascalish" background, so C seems a little foreign to me. I should check, though, does Ada still use the finger-breaking := assignment of pascal, modula and such languages?
This:
http://www.adahome.com/Ammo/Cplp...
seems to confirm := rather than =
Yes it does, and just a single = for comparison. But I think the typing aspect of programming is the very, very last thing anybody should worry about.
I've got a personal list of what-I-like-about-Ada points that I made up for some colleagues. I'll try to find it and post it. If it's true that we're about to have bare-board Ada for Cortex M3, including Ravenscar tasking, this is a Big Deal IMO. Even having non-tasking for 8-bit AVR, which is available now, is a big thing. Adding tasking to the AVR offering would be great, but I don't know if that's in the works or not.
Yea. I might like that. Ada, that is.
Actually, simple tasking isn't that hard. A "task" is simply a stack. To start a task, allocate some memory for the stack, put on the new stack the address you want to start, save the stack pointer for the running task, set the stack pointer of the new task and do a return. To change tasks, push the program counter, save the stack pointer, restore another stack pointer and do a return. The other tasking functions aren't at all hard to code either. I used to do that in Modula II for CP/M and DOS.
A personal, informal list of things I like about Ada, from a career C and C++ programmer
1) Strong typing
a. Everything is NOT just an int of N-bits (a “bucket of bits”). Typing conveys important additional information about the intent and meaning of the data and allows the compiler to easily detect inconsistencies in code or data.
2) Scalar type ranges
a. Again, everything is not just a bucket of bits, but has a valid range reflecting the actual real-world data being represented. Instead of thinking in terms of bit size (“Do I want 0 to 255, or 0 to 65535?”) one can actually model the problem data, e.g. degrees are -180 to 180, temperature is -10 to 150, encoder counts are -3_000_000_000 to 3_000_000_000. The compiler deals with choosing the underlying machine data size.
3) Full control over scope and visibility of all data and program objects
a. Exellent control over scope and visibility allows full programmer control over the allowable paths for data and functions. Goes a long way towards eliminating the “spider web” coding effect.
4) Local data and subprograms allowed almost anywhere
a. Similar to #3, allows fine control over data and function scope and visibility. Not only local variables be even local functions can be declared and nested as necessary to break up and clarify any complex section of code, while restricting visibility of those data & functions to the minimum necessary.
5) Fixed point data types (including decimal)
a. Another tool to allow more accurate and natural modeling of problem data. Instead of requiring user-program scaling of integer values as necessary, the scaling is all handled in the language, freeing up the programmer from that complexity and source of errors.
6) Modular types on any bound (not just powers of 2)
a. Nice for any kind of wrap-around counter. For example, one could have a circular buffer of 50 elements, and declare a modular index type 0..49, and an increment from 49 will automatically roll over to 0 (and a decrement from 0 will roll over to 49), exactly as you want a circular buffer index to work.
7) Subprogram overloading on both parameters and return types
a. Very useful in performing the same or equivalent manipulations on different types of data. A form of (compile-time) polymorphism. Strong typing also allows overloading on return type, which C++ does not allow due to its implicit type conversions, but which is a natural and useful extension of overloading on parameter types.
8 ) Named parameters
a. Very useful in making the intent of a function call more clear. Prevents e.g. the common mistake of confusing x,y (as in goto(x,y)) with row, col (as in goto(row,col)). Note that row, col is equivalent to y,x not x,y. Named parameters allow explicit parameter association e.g. goto(col=>x, row=>y).
9) Default parameters
a. Any or all parameters can have defaults, and any or all defaulted parameters can be overridden in any function call. Allows full control over defaults and selective overriding of defaults.
10) Records with discriminants
a. The right way to do structures and/or unions with full type safety.
11) Representation clauses
a. Allows precise specification of the bit layout of data elements, to match existing hardware and/or protocols.
12) Array indexing over any discrete type and range
a. This is a great feature. No longer are arrays limited to being indexed from 0 to N-1. Arrays can be indexed over any discrete type and range, e.g. a Bearing type could be declared from -180.0 to 180.0 (-180 degrees to +180 degrees, in 1/10 degree steps) and an array can be indexed directly by that type. Consider how much simpler and less error-prone it is to write val := Array(-145.3); vs e.g. val = Array[1800-1453] (this being one way that -145.3 might be represented as a 0-based integer index).
13) Array slices
a. Makes movement of arbitrary array segments (“slices”) easy to do and understand, without using low-level and type-unsafe memory manipulations, or looping.
14) Renaming
a. Allows localized renaming of complex identifiers to something short and simple, e.g. Velocity renames Some_Object.Controller_Arm.Params.Velocity. Greatly increases code clarity.
15) Object oriented as well as procedural programming
a. All the benefits of object-oriented programming, while at the same time retaining all the benefits of procedural programming.
16) Generics (templates)
a. Another form of static (compile-time) polymorphism, allowing fully type-safe code to be written once that can operate on a variety of different data types.
17) Concurrency (tasks and protected objects, including Ravenscar profile for efficient and safety-critical multi-tasking)
a. One of my favorites. Allows multi-tasking (including for multi-core architectures) and thread-safe data sharing by using high-level language features, rather than requiring low-level and environment-specific objects such as semaphores, mutexes, mailboxes, etc. Vastly improves the quality and clarity of the code, as well as the development time.
18 ) Strong Realtime support
a. In addition to the built-in concurrency support mentioned, the language also directly incorporates the notions of time and durations to as great a resolution as the hardware supports (e.g. 100ns). Instead of dealing in timer ticks and OS-based, time-related function calls, programs can deal directly in time intervals and delays.
19) Strong Embedded support
a. Efficient code generation (at least as good as C or C++), excellent ability to program down to the bit level (e.g. representation clauses), and the strong realtime support mentioned, combine to produce excellent embedded systems support.
20) Packages help manage large software projects
a. By breaking up large projects into self-contained packages, library packages and child packages, all with well-defined interfaces and visibility, the management of complex data and control flows is enhanced and made more containable.
21) Promotes a professional, anti-hacker mentality
By being “unforgiving” the language promotes the valuable discipline of specifying and writing code more exactly, without the temptations of slipping into bit-twiddling or other programming habits that subvert (and often break) the data or code models. When proper programming discipline is not enforced by the language then it must be voluntary, and in those cases discipline can and inevitably will slip, but when the language enforces much of that discipline then there are no easy ways to avoid it, and the resulting code is higher in quality and faster to develop.
I have a number of programming languages under my belt, including the first decent language I learned (Pascal), the first OO language I learned (Simula, although the term OO wasn't invented or at least spread at that time), C and C++. Ada is not in my CV, but your list made me very curious!
Thank you for a very tickling post!
Here's one short but interesting article on Ada. Especially revealing, IMO, is the comment that writing the software in Ada felt something like actually building the machine out of the various parts. That struck a strong chord with my own past experiences.
http://www.adacore.com/adaanswer...
OK, Ada is great. But why is it so low down in the tiobe index?
That indeed is the question.
Some of it is due to the earliest compilers from 30 years ago being very big and very slow and very expensive.
Some of it is due to historical lack of compilers for many platforms, especially embedded ones.
Some of it is due to the original mandate that Ada be used in all new military development, and the backlash that caused.
Some of it, IMNSHO, is due to a hacker mentality widespread in our industry that would rather use poor tools that are not "constricting" than use better tools that enforce more discipline on programmers than they are comfortable with.
Here's another article, this one about switching from C to Ada in a real-time software class.
http://www.crosstalkonline.org/s...
(page 22)
It's a "large" language.
Took me about three months to go (deep) through Cohen's Ada as a second language (Google); whereas, I'd estimate one would only need about one month to do likewise for C.
C was quickly on a PC; Ada via GNAT took awhile.
C compilers are ubiquitous; Ada compilers were not (If you build it, they [sic] will come) (1).
IIRC, GNAT's run-time (complete) primary target is POSIX; so it's easier to port GNAT to an OS or some (or few) RTOSs.
(1) Field of Dreams (Wikiquote).
Depends on one's definition of embedded; for microcontrollers, yes.
IIRC, a Boeing aircraft's ABS was Ada on an 8086.
btw, A new Embedded Ada book by Jack Ganssle (embedded.com; April 9, 2013) (I don't have it yet).
As a soon to be M.Sc in Cybernetics (google it), I really have to chime in on this one. I've had a couple of Ada courses together with the new Go language, and Ada struck me as one of the most... useful specifics in languages that I've stumbled across. Especially the Ravenscar Profile of the tasking system makes hard real time almost a non-brainer...
Just waiting for a Ravenscar compliant Ada runtime on the AVR :P
:: Morten
Another Ada on AVR compiler though it's still a work-in-progress (simulated AVR, etc.):
RTEMS, Wiki, AVRTest
Is this close enough?
GNAT for AVR32 UC3, Wiki
Wow, Kristoffer has been busy :P (he was the one who first introduced me to Ada)
:: Morten
Great to learn of Ada for the embedded world, and to be reminded about Ada in general. It was (gosh) over 20 years ago (1989?... yeesh) that I was first introduced to Ada in a second year university level course. The notions of strong typing, not only of data but of functions, and of the generic/instantiated model to code writing were powerful departures from my prior programming experience, which was limited to imperative or procedural languages like COBOL, Fortran, and Pascal, and before that, BASIC and Assembler.
I look forward to taking Ada for a drive in the embedded world.
JJ
IMO:
C, not C++, is really a portable assembly language. That's how it began, when K&R defined C with the PDP-8 or PDP-11 assembler and architecture in mind (like the pre- and post increment/decrement in C exploited the PDP's ability to do that in hardware.
I learned Pascal long ago. When I began with K&R C, I wanted it to be Pascal-like. Strongly typed, etc. One day, the light bulb came on: Hey! C is more like macros on top of asm. Then, I immediately got it. And C with pointers and pointers to pointers made sense.
Not defending C, but it is, IMO, the best for small memory embedded. Bounds checking of scalar's ranges or array indexes, at run time are too wasteful in a price or timing sensitive micro. Now with cheap 32 bit Cortex processors with 512K or more - my argument begins to fail.
stevech wrote:
IMO:
I agree that C is a good match for small embedded devices, and its disadvantages tend to be containable with those systems. Many (but by no means all) of Ada's advantages become more important as system size increases. But Ada also makes many useful checks at compile time (no runtime penalty at all), and runtime checks can be turned off either locally or globally, so you can dial in the amount of checking vs runtime efficiency you want.
kk6gm wrote:
Ref.
That's still not available from AdaCore; maybe this summer.
Ought to be able to take GCC 4.8 and build a cross-compiler for ARM Cortex-M EABI (bare board) and likely also a Ravenscar profile for a run-time.
The newest commercial version was released:
AdaCore releases GNAT Pro 7.2 with more ARM support by Bernard Cole (embedded.com; March 06, 2014)
Key words: distributed build, Ada 2012, C++, ARM, bare board, Linux, Android, VxWorks, LynxOS, Eclipse.
AVR-Ada is ready for use from Windows; for Linux it comes in source code form.
An AVR-Ada operator has built it for Fedora Linux.
http://fedora.ada-language.com
Tero's Arduino Blog, Using Arduino with Ada
"Building AVR-Ada and related tools (avr-binutils, avr-gcc, avr-libc) on Debian."
http://build.ada-language.com/job/AVR-Ada_Debian_7
Do you know of any Eclipse based attempts of avr-ada or any-ada?
I already use Eclipse for some architectures but that is C/C++.
I know Ada95 (GNAT) and would like to give avr-ada an IDE try.
ATMega128+32kB SRAM should do.
Specifically:
- does the avr-ada compiler generate debugging information?
- anyone tried to configure avr-gdb to work with Ada source? (nNot sure if that is different from C/C++).
- Eclipse CDT (obviously) does not natively support Ada. I have found the Eclipse Ada plug-in, I didn't try that yet and I am not sure it works as a standalone plug-in (without their whole environment). All I need is basic tools like syntax highlighting, error parsers and alike. Any known alternatives?
In general: any hints on avr + ada + gdb + eclipse?
mcrzp
No RSTDISBL, no fun!
The only one I'm aware of is for the commercial and GPL Ada tool set from AdaCore.
AVR-Ada is only the compiler and such.
AVR-Ada should be able to be invoked from GPS (an Ada-aware IDE; see AdaCore for commercial and AdaCore's Libre for GPL).
K.7 Using Gdb With Atmel mkII Probe (AdaCore, GNAT Pro User's Guide Supplement for Cross Platforms: AVR Topics)
OOTB it's for mega2560.
AdaCore GPL Ada is based on GCC 4.5.
AVR-Ada is from GCC 4.7 (XMEGA, etc) and supports more AVRs.
Brutte wrote:
I have found the Eclipse Ada plug-in, ...
Is that different than AdaCore's Eclipse plug-in?
GNATbench – Ada Plug-in for Eclipse (AdaCore, Libre)
If willing, replace Eclipse with GPS (GNAT Programming Studio).
Don't know if GDB is available with AVR-Ada.
http://libre.adacore.com/tools/
[Avr-ada-devel] How do I turn on debug in AVR-Ada
Would a mega2560 or the larger Teensy work?
http://arduino.ada-language.com/tag/mega2560.html
http://arduino.ada-language.com/tag/teensy.html
For AVR + Ada and GPS (GNAT Programming Studio) instead of Eclipse there's
Integrating 8-bit AVR Micro-Controllers in Ada by Pablo Vieira Rego (Embraer S.A.) (adademia.edu, Ada User Journal, December 2012)
"Keywords: 8-bit AVR micro-controller, GNAT AVR, Ada, ZFP."
ZFP = Zero Footprint Profile
More keywords: ATmega328P, Arduino
Pablo describes how to:
1. Add mega328P to the only AVR in AdaCore Libre GNAT (mega2560).
2. Create a GPS project file.
3. Integrate AVRDUDE into GPS (ELF to hex, burn).
4. Create an application.
AVR-Ada and 128kB AVR:
The only ready one is AT90USB1286 (Teensy++ 2.0) and that's in the repository.
If it's required to use a mega128 board then could examine the changes for Teensy++ 2.0 (likely similar).
IIRC there's no USB support in AVR-Ada; shouldn't be a problem because there's package Interfaces.C.
Ok, thanks for the comprehensive reference.
"Integrating 8-bit AVR Micro-Controllers in Ada" by Pablo Vieira Rego
[rant]Downloading that pdf with my EDGE connection was the most frustrating activity, ever!
Bloated javascript, endless questionnaire, I am Jane, 13 yo, my favorite color is pink .... no, I prefer cats.
academia.edu you %^&# are officially on my black list.[/rant]
I am so tired with that download that I am not able to study that right now. I have included that 80kB pdf here for download to save you the frustration.
2v5gf
Ada on ARM Cortex
Not much about Arduino Mega 2560 in Tero's Arduino Blog, Using Arduino with Ada.
Another Arduino (Mega 2560 also) Ada operator placed their creation in Adaino (GitHub); last update was 4 months ago.
AVR-Ada is in-progress to AVR GCC 4.9.
Building an Ada Toolchain for AVR (Arduino) on Ubuntu 14.04 LTS x64 by Matthew Scheffel.
AVR-Ada / Mailing Lists, 2014-Sep contains a proposed solution to Matthew's problem.
Isn't the mega2560 one that requires paging the program memory with a page-select (128KB page as I recall, with 16 bit word address instruction address register).
And that leads to compilers with near/far and all that rot (not needed with ARM M0/M3)
Flash data-wise there's the __memx qualifer (24 bits).
Flash program-wise, GCC uses trampolines; IAR EWAVR has a memory model that linearizes this and the __farfunc attribute.
Named Address Spaces (GCC, 6.16.1 AVR Named Address Spaces)
Product news (IAR EWAVR, maybe version 5.20)
Yes and now a GCC-based Ada compiler for Cortex-M and Cortex-R.
There's a patch to get AVR-Ada to GCC 4.9.2 :
SourceForge
AVR-Ada
beta
Ada cross compiler and libraries for AVR µCs
Brought to you by: rolf_ebert
[Avr-ada-devel] patches for gcc 4.9.2 updated
From: Rolf Ebert GCC <(e-mail address redacted)...> - 2014-11-24 17:43:39
http://sourceforge.net/p/avr-ada/mailman/message/33075516/
With some effort, AVR-Ada on a tiny85 :  http://sourceforge.net/p/avr-ada/mailman/message/32991477/
A very short mention about Ada on AVR :
YouTube
Embedded World 2016 Video: AdaCore explains Ada's shrinking footprints
Embedded Computing
Feb 25, 2016
https://www.youtube.com/watch?v=snlLuI3NmcA&feature=youtu.be&t=1m36s
GNAT Pro for bare boards
https://youtu.be/IgL-yldnUF8?t=20m13s
Bare board targets
https://youtu.be/IgL-yldnUF8?t=21m21s
  • Baselined AVR & Lego Mindstorms NXT
News for bare boards
https://youtu.be/IgL-yldnUF8?t=22m5s (about 2.5m)
via
AdaCore Tech Days 2015
https://www.youtube.com/playlist?list=PLkoa8uxigENnhoRzRAs6hu4njasX2DNa-
and
AdaCore blog
Embedded Product Line Updates
by AdaCore Admin
Mar 02, 2016
http://blog.adacore.com/embedded-product-line-update
Pat Roger’s “Embedded Product Line Update” video is now live on our YouTube channel! So, check out the latest updates about the extent of the language support that is offered.
https://www.adacore.com/gnatpro/embedded/avr
Edits : GNAT Pro AVR, blog data
Has anyone ever seen a post on Freaks about someone actually using Ada?
Seems like someone is putting a load of effort into something that is almost entirely pointless?
https://www.avrfreaks.net/forum/ada-arm-cortex#comment-1256146
I tilt at windmills wink
http://idioms.thefreedictionary.com/tilt+at+windmills
http://www.microchip.com/wwwproducts/en/atmegas128
http://www.atmel.com/about/contact/sales/default.aspx?contactType=Third%20Party%20Support%20-%20AVR# (Expertise pull-down menu, Compilers)
Almost, I'd say Ada on 8-bit AVR's is going to be an exercise in frustration, but Ada on larger ARM parts is likely realistic, and you have to admire the effort.
I saw a recent Freescale NXP Nexperia part that has 1MByte RAM and 2MBytes of FLASH for example.... , not especially cheap, but someone running Ada is not likely to be price bothered  ;)
Who-me wrote:
Almost, I'd say Ada on 8-bit AVR's is going to be an exercise in frustration, ...
Start with an Arduino :
Tero's Arduino blog
An annoyance is AVR-Ada is ZFP (Zero Footprint Profile) which one result is no fixed point math that's been in Ada from get go (Ada83); fixed point math is in recent AVR GCC C.
A work-around may be Ada's Interfaces.C package to get to AVR GCC C.
Per Pat Rogers' video, recent GNAT Pro AVR ZFP can be extended to add the fixed point math run-time library.
Who-me wrote:
... but Ada on larger ARM parts is likely realistic, ...
Yes and the run-time is more complete with some Microchip MCU in SAM4S and SAM G55.
https://sourceforge.net/projects/avr-ada/ (AVR-Ada)
http://www.ada-auth.org/standards/rm12_w_tc1/html/RM-B-3.html#I7432 (B.3 Interfacing with C and C++)
via
http://www.adaic.org/ada-resources/standards/ada12/
https://github.com/AdaCore/embedded-runtimes/tree/master/ravenscar-sam4sxplainedpro
https://github.com/AdaCore/embedded-runtimes/tree/master/ravenscar-samg55xplainedpro
via https://github.com/AdaCore/embedded-runtimes
http://www.microchip.com/developmenttools/productdetails.aspx?partno=atsam4s-xstk
http://www.microchip.com/developmenttools/productdetails.aspx?partno=atsamg55-xpro
Edit : typo
A book from one's masters thesis about AVR-Ada on a mega328-P (breadboard) for a Heart Rate Monitor (HRM)
Amazon UK
Real-Time Critical Systems: HRM Prototype & Ada Integration Kindle Edition
by Jordan Mauro-Buhagiar  (Author)
https://www.amazon.co.uk/Real-Time-Critical-Systems-Prototype-Integration-ebook/dp/B07986YGNM/
via
[Avr-ada-devel] AVR-ADA Tutorial Now Available
https://sourceforge.net/p/avr-ada/mailman/message/36205971/
The Kindle edition has the most information for 'Look inside'.
Edit: message title
bit fields work for embedded apps in ada (unlike C/C++)
