Atmel Studio 6.2 undefined reference header file
3 posts / 0 new
i had made a c project which works fine.
but i want to add some classes
so, i had create a CPP project and i paste my code here.
but i take some errors about my lcd.h file.
the error is:
undefined reference to "lcd_function"
i have 10 lcd functions and i take 10 errors
if i add the header file by solution project (right click -> add library -> browse header file)
i take 2 errors:
1. cannot fine -llcd.h
2. id returned 1 exit status
Thank you very much
