ATTiny45 Compatibility mode
3 posts / 0 new
The ATtiny15 compatibility mode is selected by writing the code “0011” to the CKSEL fuses (if any other code is written, the Timer/Counter1 is working in normal mode).
So, how do you get the fuses set to NOT compatibility mode? When I look at the fuses tab, I see:
It looks as if you have typos in the drop-down.
As far as I can see, if you choose "6.4MHz RC", you go into "ATtiny15 Compatibility" mode. Consequently you get PORTB changes, PLL changes, Timer changes, CLKPR, ...
Why do you want tiny15 mode ?
Just select a non-6.4MHz setting to recover from brain-death.
If you prefer 6.4MHz, just recalibrate the 8MHz RC to run slower via OSCCAL.
Oh. So selecting anything but the tiny 15's 6.4MHz...
I did NOT type that list
Likely translated from Norwegian to English by a Hindu with a reference book entitled "Swahili as a Second Language."
