Just tried to install avrdude 6.1 but make barfs on "../ylwrap: line 176: yacc: command not found". I was able to find a "Berkeley Yacc", installed it but no joy. My Opensuse 13.1 Yast doesn't know what yacc is, either, so I don't feel so bad. Any suggestions? thanks, paul
avrdude needs yacc? Not Byacc?
Install bison. It is a GNU implementation of yacc and it will provide yacc command.
Ahhh thanks Alexru - but now I get some BS about lexer.c:
- paul@linux-dvlb:~/Projects/avrdude-6.1/obj-avr> sudo make
/bin/sh ../ylwrap ../lexer.l .c lexer.c -- :
make all-recursive
make[1]: Entering directory `/home/paul/Projects/avrdude-6.1/obj-avr'
Making all in .
make[2]: Entering directory `/home/paul/Projects/avrdude-6.1/obj-avr'
gcc -DHAVE_CONFIG_H -I. -I.. -DCONFIG_DIR="/etc" -Wall -Wno-pointer-sign -g -O2 -MT libavrdude_a-lexer.o -MD -MP -MF .deps/libavrdude_a-lexer.Tpo -c -o libavrdude_a-lexer.o `test -f 'lexer.c' || echo '../'`lexer.c
gcc: error: ../lexer.c: No such file or directory
gcc: fatal error: no input files
compilation terminated.
make[2]: *** [libavrdude_a-lexer.o] Error 1
make[2]: Leaving directory `/home/paul/Projects/avrdude-6.1/obj-avr'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/paul/Projects/avrdude-6.1/obj-avr'
make: *** [all] Error 2
It looks like this "/bin/sh ../ylwrap ../lexer.l .c lexer.c -- :" was supposed to create "../lexer.c", but did not.
Why not just install avrdude from the repo?
I've just tried on Mint and simple
./configure make
worked without any problems.
Try without sudo.
I think this have happened to me too. I had to de-install both byacc and bison and install only bison after that IIRC.
thanks, guys, I'll try that tonight - paul
If you never figured this out, the solution is to install `flex`. The configure script builds an invalid Makefile if flex isn't installed, but yacc/byacc is, instead of throwing an error.
