AVR stable variable
11 posts / 0 new
How can I declare a stable variable which does not lost data even in case of power of?
Also I want to change this variable in any time without lost data and force me to set up again even the mcu turned off.
Check into using EEPROM.
In consideration of others, please RTFM!
Declaration of variable in combination with data of eeprom it's necessary?
Each time that I read the eeprom it's must to put the data(of eeprom) in some variable in my program?
I don't want to declare a variable, in this case just for haven't commitment in memory.
It is possible? TO manage a position of eeprom without to draw the data in some variable.
Or something like that it's must be?
With AVR GCC, yes. Some other compilers provide a more seamless experience with EEPROM-based variables.
int EEMEM foo_in_EE;
int main(void) {
  int foo_in_SRAM;
  foo_in_SRAM = eeprom_read_word(&foo_in_EE);
  foo_in_SRAM = do_some_stuff(foo_in_SRAM);
  eeprom_update_word(&foo_in_EE, foo_in_SRAM);
The term you're looking for is "non-volatile" or, perhaps, "persistent"
Well that part is not true. It's quite possible to write something like:
PORTB = eeprom_read_byte(&eevar) ;
Which involves no intermediate variable (the compiler will just read to R24 then write to the port).
I'm using avrstudio 6.1
I'll try to do with eeprom read/write functions and eeprom.h maybe.
Was there a question in that?
Its a simple concept. The user chooses the value he wants, it gets written to eeprom for later, and also stored in a ram variable. I use the same name but add ee to the eeprom name. When you turn the avr off then on, it restarts, refreshes the ram var from eeprom, and you are back in business with the value you saved before.
