4N35 vs H11G1 Opto's
6 posts / 0 new
Hi Guyzz
I have two types of Optocouplers here at home
1: http://www.ortodoxism.ro/datashe...
2: http://www.fairchildsemi.com/ds/...
Until now i have only used the 4N35 , as i can not really understand the "advantage"/force of the H11G1.
Where would i use the H11G1 ???
As i undestand it : It is temperature stable due to the build in resistor , and i think i can see that you can drive 150ma continuous with it.
That CTR they talk about is that the "hfe" ???
Any hints or explanations would be appreciated , i have around 100 of each , and would like to use them :-)
Edit: Added the correct 4N35 ds URL
/Bingo
Ohh They are named QTC H11G1
So i guess they are QTC ones
/Bingo
Three or four important differences:
The 4N35 turns off a lot faster. (2uS vs 100)
The 4N35 has a much better "low" output. (0.3V vs 1.0)
The 4N35 has a much lower "dark current".
The H11Gx output stage is rated for a higher voltage.
The H11G has a Darlington output. This means more gain but higher saturation voltage and slower switching speed. Higher gain probably means that the LED can be run at a lot lower current.
It also appears that the rated output breakdown voltage is higher though that is not a function of the Darlington connection.
The H11G has a current transfer ratio of 1000% (e.g. current gain of 10); the 4N35 is 100%..
Thanks Guyzz
So i guess , for normal use the 4N35 is really the best choise.
The H11G is for "picking up" a signal without loading it (the led uses less current or ??) , and the H11G can drive a higher voltage on the output , but reacts a lot slower when turning off.
For AVR use i guess the "low" 1v output would not be important , but what about a HCTxxx (Well i can look that up).
/Bingo
