an AVR 7 segment library
11 posts / 0 new
if someone is interested, i've released an atmega seven segment library.
It runs both on common anode, and common cathode display.
You can find it here:
http://davidegironi.blogspot.it/...
i've used a lookup table to write ascii char to display.
this is the table:
//lookup table ascii char to 7 segment
#define SEGN 0xFF
#define SEGU 0xF7 //unknown way of display this character
static const uint8_t PROGMEM sevsegascii_table[] = {
	SEGN, SEGN, SEGN, SEGN,
	0xc0, 0xf9, 0xa4, 0xb0, // 0 1 2 3
	0x99, 0x92, 0x82, 0xf8, // 4 5 6 7
	0x80, 0x90, SEGN, SEGN, // 8 9
	SEGN, 0x88, 0x83, 0xc6, //   A B C
	0xa1, 0x86, 0x8e, 0xc2, // D E F G
	0x8b, 0xcf, 0xe1, SEGU, // H I J _
	0xc7, 0xc8, 0xab, 0xc0, // L M N O
	0x8c, 0x98, 0xaf, 0x92, // P Q R S
	0x87, 0xc1, 0xe3, SEGU, // T U V _
	SEGU, 0x91, 0xa4, SEGN, // _ Y Z
Instead of magic numbers, I'd use macros to define what bit is what segment. Makes it more universal.
May want to post the schematic to see HOW the display needs to be wired up in order to work with your table. :wink:
Or at least which port bits go to which segment.You can see that my table is different to yours for say 0 and 1
;7 Segment look up table. Bits assignment:
;Bit 0=Seg A, Bit 1=Seg B, Bit 2=Seg C, Bit 3=Seg D
;Bit 4=Seg E, Bit 5=Seg F, Bit 6=Seg G
;Decimal point can use Bit 7 by oring Segment data
;with 80H
lk_up_tbl_7_seg:
;0,1
.db	0b00111111,0b00000110
(0x3f and 0x06) also you seem to have the digit order reversed ie 1 0 3 2??
i've searched for some macro, but i can not find one.
can you suggest me one?
Just something like this:
#define SEG_A 0x01
#define SEG_B 0x02
SEG_A | SEG_B | SEG_G.
SEG_B | SEG_G,
@js
i've add the schematic in the first post.
as an example, take number 0
which is a,b,c,d,e,f=1 g,dot=0
portb is
dot g f e d c b a
0x 0 0 1 1 1 1 1 1 = 0x3F
my display is common anode, so is
dot g f e d c b a
0x 1 1 0 0 0 0 0 0 = 0xC0 or = 0xFF - 0x3F
if i've made some mistake please correct me,
thank you.
#define SEG_A 0x01
#define SEG_B 0x02
SEG_B | SEG_G,
my first table was like your post, but later i convert it to hex numbers, which is less readble i know :(
Hi guys,
Thank you.
Dear I am using your 7-segment library function from http://davidegironi.blogspot.it/... ... brary.html
but I have to display float values on three 7-segment display.
How to display floating values from 00.0 to 999.
for example:
00.0-00.1-00.2-----00.9-----01.0-01.1-01.2-----01.9
02.0-02.1-----02.9-03.0------09.0----09.9-10.0-10.1-10.2------20.0-----90.0----99.0---99.8-99.9-100-101-102-103-------200---500---800--900---980---999 then roll over to 00.0
Beware - cross post above. Member imranahmed already has the subject open in this thread: https://www.avrfreaks.net/index.p...
I wonder exactly how many times you intend to ask the same question? Do you think you are magically going to get new/different answers just because you ask again?
You were told before that sprintf() will convert a float to some individual digits. You then need to "post process" those a a bit to convert from ASCII to BDC (basically subtract '0' from each digit) and then also deterine where the d.p. is and light up the corresponding d.p. segment on the 7-seg. And that is it. Which bit of this are you having trouble implementing?
Excuse me, but what happens if one uses different ports for displaying a character (I wrote a python script to handle this case and generate some gcc code -untested on real HW : just looked at the generated code and showed it- : I did not look at the multiplexed case, but common anode was derived fom common cathode by inverting bits). This is not a rae case -for LCD, it often happens, too-, as PCB layouts may be made simpler by using different parts of different ports...
