C++ Fooling with forces beyond my understanding
10 posts / 0 new
Curious as always, I thought I'd spend some time playing with C++ on my current project. This has an xMega chip.
I found "Jax Coder's" page at http://jaxcoder.com/Projects.asp... and blinking an LED seemed an appropriate first task for making a class.
I had to adapt his class to xMega by adapting the class:
CBlink.h
 * CBlink.h
 * Created: 7/20/2014 2:41:00 PM
 *  Author: Tom
#ifndef CBLINK_H_
#define CBLINK_H_
class CBlink
	public:
	//Constructor with the last parameter set to false as default.
	CBlink(volatile PORT_t * port, uint8_t pin, bool initiallyLit=false);
	bool IsLedLit() { return m_isLedLit; }
	void SetLitState(bool state);
	void ToggleLitState();
	private:
	bool m_isLedLit;
	volatile PORT_t * m_port;
	uint8_t  m_pin;
#endif /* CBLINK_H_ */
(Curiously, the clipboard has been working of late. Perhaps fixed by an MS update?)
CBlink.c
 * CBlink.cpp
 * Created: 7/20/2014 2:41:16 PM
 *  Author: Tom
#include
#include "CBlink.h"
CBlink::CBlink(volatile PORT_t * port, uint8_t pin, bool initiallyLit/* =false */)
	//Set the port addresses for the DDR and PORT values
	m_port = port;
	//Set the DDRn.pin as output
	m_port->DIRSET = _BV(pin);
	m_pin = pin;
	m_isLedLit = initiallyLit;
	//Set initial state of the LED
	SetLitState(m_isLedLit);
void CBlink::SetLitState(bool state)
	m_isLedLit = state;
	if (m_isLedLit)
		m_port->OUTCLR = _BV(m_pin);
		m_port->OUTSET = _BV(m_pin);
void CBlink::ToggleLitState()
	SetLitState(!m_isLedLit);
Things went haywire when I tried to build the app, because there wasn't any _cplusplus.h Not knowing what else to do about it, I deleted the include statement, and my app builds and... egad, the led blinks!
 * LearnC__01.cpp
 * Created: 7/20/2014 2:37:23 PM
 *  Author: Tom
#define F_CPU 2000000
#include
#include
//#include "_cplusplus.h"
#include "CBlink.h"
	CBlink  blink(&PORTA,3);
		blink.ToggleLitState();
		_delay_ms(2000);
He includes what looks like the _cplusplus.h file, so I added that:
 * _cplusplus.h
 * Created: 7/20/2014 3:22:50 PM
 *  Author: Tom
#ifndef _CPLUSPLUS_H_
#define _CPLUSPLUS_H_
    This is applicable if using virtual inheritance.
__extension__ typedef int __guard __attribute__((mode (__DI__)));
extern "C" int __cxa_guard_acquire(__guard *);
extern "C" void __cxa_guard_release (__guard *);
extern "C" void __cxa_guard_abort (__guard *);
int __cxa_guard_acquire(__guard *g) {return !*(char *)(g);};
void __cxa_guard_release (__guard *g) {*(char *)g = 1;};
void __cxa_guard_abort (__guard *) {};
    This is applicable if using pure virtual inheritance.
extern "C" void __cxa_pure_virtual(void);
void __cxa_pure_virtual(void) {};
    Operators required for C++
void* operator new(size_t size);
void operator delete(void* size);
void * operator new(size_t size)
    return malloc(size);
void operator delete(void* ptr)
    free(ptr);
#endif /* _CPLUSPLUS_H_ */
But when I try to include this code I don't understand, I get errors I don't understand. Strange, how that works, uMM?
Under Operators required for C++
The error points to size_t and says two things:
"size_t was not declared in this scope" which is pretty obvious that it doesn't know what a size_t is.
Um, so is there something more I need to know about using C++ in studio 6.2?
I believe it's now time for a Sunday Afternoon walk.
size_t is defined in stddef.h. Try including that at the top of _cplusplus.h (or better stdlib.h which includes stddef.h).
Steve A.
That header file is not part of the avr-gcc tool chain (was not in WinAVR, is not in Atmel toolchain).
The header file contains prototypes for dynamic object creation with the new operator, object destruction (delete) etc. It does not contain definitions (implementations) of them.
As they came/come neither of these tool chains has implementations of the this new operator etc. If you don't need it, and the trivial code above does not use it, then just don't include that file. The formulation "needed for C++" is not correct. It should be "needed for dynamic object allocation/destruction" or some such.
If you need new/delete, perhaps not include that file (since it is not a complete solution) but search out the (long) discussion in the avr-gcc forum on getting avr-gcc to do C++.
Apart from that: size_t (which is not specific for C++, but there even in C) is typedef'ed in stddef.h. This file is in turn included from a lot of other header files in avrlibc (e.g. stdlib, stdio, string..).
Hmm. Not sure I'd use new to get pointers to new objects, but object initialization and destruction seems a main feature of c++. Maybe I'll seek out that thread. However, it's a beautiful Sunday Evening in Tulsa, and I think I'll go back outside for a while :D
I see the trivial class having a construct method. Is there a way to make a destruct method so I can goof things up when the instance goes out of scope?
"It takes strength to resist the dark side. Only the weak embrace it!
It is more powerful than you know..." Obi-Wan Kenobi
It seems to me C is the dark side. And I used to use FORTH, so I KNOW darkness
Torby wrote:
I KNOW darkness
No you don't:
http://nickm.com/cis/a_box_darkl...
Yes, it is a central concept of C++, however it applies to all objects, not just the ones that are dynamically created. If you have a class Foo, then:
void function()
    Foo foo;
when this function is called, the constructor of foo is called, and when the function ends, the destructor of foo is called. No new or delete in sight.
class Foo
   Foo(); //constructor
  ~Foo(); //destructor
Easy to find: it is a sticky thread in the gcc forum.
Steve A.
One problem here is assumption and ignorance. You can get construction and destruction without new/delete operators. The key word for new/delete is "dynamic". It does not matter how you allocate an object. A constructor will run. It is only for dynamic allocation you need new/delete.
It is rare to learn C++ only by looking at examples and not doing serious reading of books etc.
And be aware that while C is a quite small language C++ is a large language.
I think my curiosity it settled for a time.
