How to write GCC plugin to work with avr-gcc
8 posts / 0 new
Hi guys,
I have a gcc plugin which works for my simple test (non embedded) programs. And, I load the plugin as
g++ -fplugin=path_to_plugin_so/plugin.so -c test_prog.c
However, the end goal of my plugin is to work with avr-gcc for embedded programs.
In usual case, I build my simple embedded program (lets say em_prog.c) as
avr-gcc -mmcu=atmega8 em_prog.c
where atmega8 is the host micro-controller name.
My question is - how do I now make my plugin work with '-mmcu=atmega8' option and with avr-gcc?
I tried
g++ -fplugin=path_to_plugin_so/plugin.so -mmcu=atmega8 -c test_prog.c
and
avr-gcc -fplugin=path_to_plugin_so/plugin.so -mmcu=atmega8 -c test_prog.c
But none of these work.
Can someone please help me with it? I am badly stuck at this point.
Thanks and regards,
Sandeep.
Thanks and regards,
Sandeep K Chaudhary,
University of Waterloo, Canada.
Maybe the compiler driver (avr-gcc) does not pass on the -f to the compiler proper (avr-g++)?
Have you tried
avr-g++ -fplugin=path_to_plugin_so/plugin.so -mmcu=atmega8 -c test_prog.c
I had a quick look into the GCC docs and it seems the -plugin (and the whole plugin API) was introduced in 4.9.0.
What version of GCC is your avr-gcc based on? Did you build it yourself, or are you using e.g. the toolchain supplied by Atmel? If the latter: I don't think they are basing it on the latest GCC.
The next-to-latest Atmel toolchain 3.4.2 was based on GCC 4.7.2, which is a bit behind the 4.9.0.
I will not install toolchain 3.4.4 to check what it is based on, and as usual Atmels release procedures are lacking - there is nothing in the release notes next to the distribution which could tell us about it..
Do
avr-gcc --version
on a command prompt to get something like this:
avr-gcc (AVR_8_bit_GNU_Toolchain_3.4.2_992) 4.7.2
Copyright (C) 2012 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
In there you see that my Atmel tool chain is based on 4.7.2.
If you are into GCC internals, then mailing list gcc-help@gcc.gnu.org is a much better place than here.
You will have to be more specific about what "none of these work" means, how you configured your compiler, etc.
But with almost 100% certainty, this is pointless here.
Atmel's 3.4.4 is based on GCC 4.8.1
Here's a snip from my own build of Atmels 3.4.4 sources.
$avr-gcc -v
Using built-in specs.
COLLECT_GCC=avr-gcc
COLLECT_LTO_WRAPPER=/usr/local/avr/libexec/gcc/avr/4.8.1/lto-wrapper
Target: avr
Configured with: /home/bingo/1-Build-Avr-GCC/Atmel-3.4.4/builddir/src/gcc/configure LDFLAGS=-L/usr/local/avr/lib CPPFLAGS= --target=avr --host=x86_64-pc-linux-gnu --build=x86_64-pc-linux-gnu --prefix=/usr/local/avr --libdir=/usr/local/avr/lib --enable-languages=c,c++ --with-dwarf2 --enable-doc --disable-shared --disable-libada --disable-libssp --disable-nls --with-avrlibc=yes --with-mpfr=/usr/local/avr --with-gmp=/usr/local/avr --with-mpc=/usr/local/avr --enable-fixed-point --with-pkgversion=AVR_8_bit_GNU_Toolchain_3.4.4-Bingo-_201406211801 --with-bugurl=http://www.atmel.com
Thread model: single
gcc version 4.8.1 (AVR_8_bit_GNU_Toolchain_3.4.4-Bingo-_201406211801)
/Bingo
No, gcc has had plugin support for a while. I know plugins work on 4.7.x - I wrote one myself. But yes, the gcc-help mailing list is the right place to discuss this further.
Regards
Senthil
blog | website
OK. I just did a dig around the GCC documentation re options. It seems to me that while plugins might have been around for a long time as you say, the -fplugin option was added quite recently. OR at least wasn't documented until quite recently.
Thanks a lot for the reply guys !
My avr-gcc is based on 4.8.2.
sandeep@ubuntu:~/ispec/tool/gcc_plugin/gimple$ avr-gcc --version
avr-gcc (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
So if the latest avr-gcc is older than 4.9.0 then how do I get around this?
How can I know what version of gcc the latest avr-gcc is based on?
And, yeah - I did asking this on gcc-help@gcc.gnu.org but didn't get any response on this forum. That's why I asked it here.
Thanks and regards,
