HOw to make C header files?
2 posts / 0 new
So i wrote my own LCd code. What i want to do, is put it all into a header file (LCD.h), and then be able to call it from another file, so that i can use the functions in LCD.h...
i'm clueless on how to do this..
any suggestions?
does anyonehavea resource that shows me how to?
The best resource is other header files.
If you are using WinAVR C or other language package you have a bunch ready to go and to use as a pattern to follow.
Once you get the hang of writing your own, you'll never be stuck when a new device comes out you want to use. Just sit down with the datasheet and start building.
One thing though - you might not want to change existing header files as then you are stuck re-coding every time a new version comes out. I'd create your own library of header files with whatever definitions/functionality you are wanting.
If you mean actual code, that doesn't go in a header file. That would be for a library of C functions for example.
Please note - this post may not present all information available on a subject.
