Very cheap Mega128A board
14 posts / 0 new
I couldn't resist ordering one of these boards:
http://www.ebay.co.uk/itm/151278...
for £9.30 including postage.
I'll let you know what I think of it when it arrives.
It seems to be based on this PCB from ITEAD:
http://imall.iteadstudio.com/ope...
Leon Heller G1HSM
Mind this is m128 (non-A) so it is supposed to work only on 5V (according to DS). The m128A operates in 2.7-5.5V range.
I see some discrepancy about this board.
For a complete noob m128 is an overkill.
Most noobs won't be even able to RTFM of m128, not mentioning respective ANs. It is just too big.
M32 or M162 in PDIP + breadboard are IMHO better noob propositions (JTAGICEMk1) as one can buy 5 of them for £10 locally and it is very easy to wire that. Of course if someone owns Mk2 and up then m1284-PU is always a noob winner.
And for someone who wants something serious - wouldn't it be grand if it had at least 32kB of external SRAM?
No RSTDISBL, no fun!
It says it is an ATmega128A.
It isn't claimed to be intended for beginners.
Leon Heller G1HSM
But the photo of the board shows an ATmega128.
OTOH the picture and some of the description mentions m128 (non-A). Ask the seller, just to make sure.
Anyway, it is definitely usable.
They have also routed PEN to pin header!
rqyem
Why? If I was a beginner these days I'd probably buy a mega1284P. Nothing says you HAVE to use every last resource in it but on the day you wire it up to an SD and a GLCD and want to do picture decompression or something that 16K RAM sure is going to help things along! Admittedly it looks like a waste of resource if you simply flash an LED with a soft delay. But if you were only buying one chip/board does it really matter if it's $2 or $10 ?
The photo shows a chip manufactured in 2006.
I would guess that current deliveries will use recent chips. e.g. mega128A
I am sure that Leon will get on fine with the bare dev board.
However, for a similar amount of money, you could buy an Arduino MEGA clone e.g. [url]http://www.ebay.co.uk/itm/Mega-2560-R3-ATmega2560-16AU-Board-Arduino-com... for £10.95 from UK
or [url]http://www.ebay.co.uk/itm/Microcontroller-Board-ATmega2560-16AU-USB-Cabl... for £8.55 from China.
Ok. You need an ATMEL-ICE, JTAGICE-3, DRAGON, ... to run the JTAG.
But personally, I find that the built-in UART comms + bootloader make any regular Arduino ideal for prototyping. And of course, all the shields are interchangeable.
And actually, I prefer the UNO as a general purpose platform.
True but for me it is always a matter of comparing alternatives (relative values):
    Mentioned m128 or other goodies.
and not the decision if something is worth £2 as such (in absolute value).
So if I were to chose some stuff for playing with avr8s then it is either a bucket of m16/m32 or one m128+SRAM. But it is mood dependent.
Indeed - and I would strongly recommend that beginners should avoid cheap stuff like this.
Just look at their description:
leader-foreign-trade-llc wrote:
2. The AD transform reference voltage added filter inductance and capacitance;
3. Through the jump line can choose different frequency external crystals;
4. All are drawn and mark IO mouth;
5. ISP and JTAG interface are drawn and mark;
6. Reliable reset circuit;
7. PA1, PA0 out two LED for simple test
A reasonably experienced user can draw some sense from that gibberish - but it's not going to help a beginner.
If there is any documentation, it's likely to be to a similar standard - again, not helpful for a beginner.
And support? Forget it!
This is why they're so cheap :!:
#NoSuchThingAsAFreeLunch
The board has just been delivered. It has got a Mega 128A.
Leon Heller G1HSM
I make that 9 days delivery. Pretty good service from China Post!
And I bet the date code on the 128A is 2014.
The only marking that looks like a date code is AU 1333. Does that make any sense?
Leon Heller G1HSM
Week 33, Year 2013.
So I do NOT win a coconut!
That's good to know. The earlier chips seem to have had several errata.
Leon Heller G1HSM
