Dear all
I wanted to start a PCB house, I need this capability's for it,
First of all it's actually two Manufacturing lines, one for low tech and low cost designs which would be used for 4layer and lower, 6mil track and space,and 0.3mm hole size,
The second line should be used for higher tech PCB's
I want it to be able to do at least 2 or 3 mil space/width, 0.1mm hole size and have a laser drill capability too,Impedance control and embedded passives capability's, and could do at least 32 layers,Also I should be able to do flex PCB's as well.
So what equipments do you suggest to buy,
Any Ideas are welcome.
