Toggle a Single PORT Bit on / off ? alternative ?
17 posts / 0 new
I tried to toggle port Bit On / off using
PORTD |= (1<<PORTD7);
PORTD |= (0<<PORTD7);
but its not working.
Searching more i found
PORTD |= _BV(PD7);
PORTD &= ~_BV(PD7);
Which seems to be working...
is there any other way out to toggle individual port ?
Yes. Read the data sheet of your AVR.
Modern AVRs allow:
PIND = _BV(PD7);   //note this = and not |=
If you're after "toggle" as in "change the pin to the opposite state of what it is now" then you want the "exclusive-or" operator
PORTD ^= _BV(PD7);
As david hints, modern AVRs have this implemented in hardware: You write a 1 to the appropriate bit in the PIND register when the pin is an output.
I would consider coding this with the C exclusive-or operation as I did above, and check that the compiler actually generates the single SBI opcode for it. This makes the code portable to non-modern AVRs, preventing a possibly very confusing bug hunt.
If by "toggle" you actually mean "set pin to 1" and "set pin to 0" then these (that you mentioned above) are good:
PORTD |= _BV(PD7);
PORTD &= ~_BV(PD7);
Do you know of any AVR compiler that actually does that? That is it converts:
PORTB ^= (1 << 5);
to
PINB = (1 << 5);
I don't believe any of them perform that particular parlour trick. I would love to be proved wrong.
Darn..
No, I never have investigated this myself.
If the compiler does not do this, then it will be necessary (at least in some cases) to take height for the non-atomicity of the operation. Now some of the point with keeping it tidy (C-wise)(IMO) is lost.
That would tend to violate rules surrounding volatile access, wouldn't it? I'd guess that if you write:
PORTB ^= (1<<5)
... the compiler is obliged to touch PORTB. It is an feature of the hardware, not the language, which allows you to substitute PINx for PORTx.
Of course the same could be argued regarding the behaviour that replaces:
in  r24, PORTB
ori r24, (1<<5)
out PORTB, r24
... with:
sbi PORTB, 5
... in this case the result is exactly the same: bit 5 in PORTB is set. There are no side-effects to reading (or not reading) PORTB, nor in writing (or not writing) the adjacent bits.
In the case of toggling:
ldi r25, (1<<5)
in  r24, PORTB
eor r24, r25
out PORTB, r24
... replaced with:
ldi r24, (1<<5)
out PINB, r24
... again the result is exactly the same: bit 5 in PORTB is toggled. Again, there are no side-effects.
The difference in the latter case is that a different I/O register is accessed. I expect this is far enough outside the constraints of volatile access for it to be excluded. Given the lack of any side-effects however, it does seem a safe optimisation to make. Do you think a feature request will be well-received? ;)
True, but there is always atomic.h:
ATOMIC_BLOCK(ATOMIC_RESTORESTATE) { PORTB ^= (1<<5); }
The down-side is that the ATOMIC_BLOCK wrapper can be dropped if the body of the bock is reduced to a single machine instruction. Another feature request? ;)
I'd have to hunt out the prior threads, but IMO/IME "much ado about nothing".
In any real app,how often do you actually toggle a port bit for important purposes? I tend to only use it for relatively trivial ends, such as toggling a port pin in an ISR for 'scope/LED indication.
IMO save the effort for more important things.
IME as these operations come up rarely...
#define TOGGLE_STATUS_LED() (PINB=1<<5)
...looks like
   TOGGLE_STATUS_LED();
in the code. One can always make a more elaborate macro.
Agreed. I thought the smilie gave it away...
I've done it, in assembly, for high-speed bit-banging.
That said, if one really wants:
#define toggle(p, mask) \
    if(HAS_PIN_TOGGLE) PIN ## p =(mask); else PORT ## p ^=(mask);
#define atomic_rs_toggle(p, mask) \
    if(HAS_PIN_TOGGLE) PIN ## p =(mask); \
    else { \
        char scratch; \
        asm (" IN __tmp_reg__, __SREG__\n" \
             " CLI\n" \
             " IN #[scratch], #[port]\n" \
             " XOR #[scratch], #[mask]\n" \
             " OUT __SREG__, __tmp_reg__\n" \
             " OUT #[port], #[scratch]" : [scratch] "=r"(scratch) : \
                 [port] "I" (_SFR_IO_ADDR( PORT ## p )), \
                 [mask] "r" ((char)(mask)) ); \
#define atomic_fo_toggle(p, mask) \
    else { \
        asm( " CLI\n" \
             " IN __tmp_reg__, #[port]\n" \
             " XOR __tmp_reg__, #[mask] \
             " SEI\n" \
             " OUT #[port], __tmp_reg__\n" : :
                 [mask] "r"((char)(mask)) ); \
'Tis up to the user to #define HAS_PIN_TOGGLE .
"Demons after money.
Whatever happened to the still beating heart of a virgin?
No one has any standards anymore." -- Giles
Asking - you need to read the bit manipulation tutorial methinks. See the tutorial section.
Now that might be worth a feature request. How hard can it be for AVR Libc to include a single macro in the header files for devices which support it?
Arghhhh...! A MACRO! My eyes, my eyes...! :wink:
Indeed. then in your bit-bang loop you are well aware of PINx writes for the feature. In fact, you probably tackled the whole thing with the knowlege of the single-instruction toggle. Just do it. (A corollary is bit-banging e.g. I2C -- the bit is turned on/off by manipulating the DDRx bit, not the PORTx bit.)
[flame bait] What AVR8 apps designed fresh in the last 10 years or so use an AVR8 model >>without<< that feature?
What would be the point of a one line macro anyway? What? Something like:
#define TOGGLE(p, n) PIN ## p = _BV(n)
or similar? Why wouldn't the programmer just write:
PIND = (1 << 3);
rather than:
TOGGLE(D, 3);
What does the macro actually gain you in this circumstance? It's a bit like these:
sbi(PORTD, 5);
macros that people use. How does that really help compared to:
PORTD |= (1 << 5);
It can be changed to this for older devices:
#define TOGGLE(p, n) PORT ## p ^= _BV(n)
... or something similar to skeeve's suggestions for atomicity.
I over-simplified the macros for ease of exposition.
Instead of ## I would invoke the paste macro
#define xpaste(x, y) x ## y
#define paste(x, y) xpaste(x, y)
That way one could do something like
#define LCD_LETTER B
#define LCD_BIT 3
toggle(LCD_LETTER, 1<<LCD_BIT);
even
#define toggle2(x) toggle(paste(x, _LETTER, 1<<paste(x, _BIT))
toggle2(LCD)
