ICE200 and Studio 4 not working properly.
2 posts / 0 new
I can't get the ICE200 to work properly with Studio 4 (V4.11 Build 406, SP2), although it is fine with Studio 3.56. Chip is the '2313 and I'm using WinXP Home. The program won't run with F5 or single-step with F11, although it will single-step with F10.
Has anyone else had this problem?
Leon
Leon Heller G1HSM
YES for about a year and Atmel could not replicate my problem. Studio 4.11 now works PERFECTLY with the ICE200 ....HOWEVER...it will NOT work with the Motherboard's com1 and com 2 ports!! I ended up using a PCI serial card which has it's own driver (Sunix on Location 10 whatever that is) and since then (about 4 months now) I cannot break the ICE200. The same thing happens with my laptop running win 98 and the fix was to just use a USB to RS232 adapter. So it seems that Studio 4.xx (all so far) has some serious "issues" with the serial comms which I believe is the source of repeated trouble in upgrading the firmware in Atmels' tools. The above also fixed annoying problems with Studio 3.5 which would continually break into a disassembly window whilst running a program. Mind you other user seem not to have any problems at all. Please let us know if the above fixes your problem.
