Since I select the fuse bit that set the micro to use the external crystal the avr dragon can't enter programming mode again. The crystal is: http://pt.mouser.com/Search/Prod...
My circuit:
How can I verify if the crystal is oscillating? If it help I have the following logic analyser http://dangerousprototypes.com/d...
Thank you
