STK500 running slow and sloooower
8 posts / 0 new
Hello:
I have been using the stk500 for a good while programming the atmega48. However about a week ago it began running VERY slowly...What used to take 15 seconds to program a device now takes about 2 minutes (whether chip on stk500 or using ISP & target PCB).
I happen to have a 2nd stk500 & simply swapping them out gives me my original high programming speed (using the same target board), Is there some sort of speed setup that is remembered in the STK500? I can't seem to find any "setups" to chage this. Both STK's have the same jumpers installed, only one is about 8 times faster than the other. What's wrong? Both are set to use the stk500 3.69 Mhz clock (but I don't think this would changed the ISP programming speed)
Hoyt Clagwell
Think i read that the new firmware upgrade that gets installed in stk500 (well it was the AvrISP but might also apply to stk500) , when upgrading to the newest : AVR Studio
Initially lovers the spi speed , as default.
You might want to check that setting (but i dont know where .... it must be somewhere in studio)
/Bingo
I am still having trouble with this stk500...it is very slooow...for some reason it has slowed way dowm...but the clock is still selected as 3.69MHz....any thoughts? Its driving me crazy
Hoyt
any thoughts on why this is running so slow
Hey,
Did you try adjusting the SPI speed - not just the clock speed, but if you have V2.0 firmware the SPI speed.
-Colin
To avoid misunderstandings "SPI-speed" is called "ISP Freq." in the AVRStudio 4.11SP2 STK500/AVRISP-plugin for firmware 2.x (in the Board-Dialog). The ISP-Freq. does not depend on the setting in "STK500 Osc" which is the clock the STK500 generates for a target that is not "fused" to use its internal RC.
thatnks for the tip on ISP speed...now where & how do you set it?
I have experienced the same problem with the STK500. I eventually cured it by reprogramming the STK500's firmware. See AVR Studio's help.
Hope this works for you too.
Good luck.
Pete
