SP2 for AVR Studio
8 posts / 0 new
SP2 for Studio 4.11 is available from http://www.atmel.no/beta_ware. It fixed a problem I was having when programming the Tiny11 with the STK500.
Leon
Leon Heller G1HSM
It didn't fix my problem with ICE50!
Assembler 2 is still buggy.
Attempt to redifine keyword OR
.equ OR =3
The above line is in the 8535.inc file
Attempt to redefine keyword SUB
.equ SUB =0x1A ;^Z Substitute
The above line is part of my ASCII definitions file.
Illegal reuse of instruction 'adc' as label
ADC: (followed by ISR code)
Yet the data sheet show:
rjmp ADC ;ADC Conversion Complete Handler
Assembler 1.77 is still buggy (I know it's no longer supported).
Gargabe at the end of line.
cpi r16,'#'
Happily V1.74 of the assembler works well, so i'm sticking to that version :D . I hope SP2 has fixed other things and not broken others.
Anyone knows if the servicepacks are culmulative
I now have a "Studio" , a servicepack 1 and a servicepack2
And i have appied both sp1 & sp2 ... just wondered
/Bingo
hello bingo,
first install studio (build 401) and afterwards sp2 (build 406). this should work.
regards
gerhard
@gerhardf ... thanx
I also noticed you should install the CAN addon if you want to try that one , its not included in SP2
And hence the above , the support for Tiny11 is probably not included too
/Bingo
I think you need the ICE50 hardware to make use of the CAN plug in.
@MikeB
In the GCC forum https://www.avrfreaks.net/index.p...
I did simulate a test program made for CAN , but at first i got an error.
Then i installed the CAN plugin , and there was no error.
This was not a program that used any CAN features , just a test to help out.
/Bingo
