How to compare project files?
4 posts / 0 new
Is there a utility to give a meaningful comparison of two project files?
I say "meaningful" because, even though they are plain-text files, Atmel Studio seems to make no effort to keep the content in any consistent order - so "normal" text comparison utilities fall over because, even though the files may be equivalent, the content is "shuffled"
A cynic might say that it appears to make efforts to ensure that the content is not in any consistent order :!:
:x
Eclipse seems much the same
Wonder if this might work...
http://diffxml.sourceforge.net/
Certainly looks worth investigating - thanks!
In fact, in the linked blog, someone asks essentially my question:
http://www.adrianmouat.com/bit-b...
(see the 1st comment - John Knottenbelt, May 20th, 2009 at 10:07 pm)
