Shrinking a 1024x768 to 320x240 ?
99 posts / 0 new
Guys,
Does anyone know on how to shrink a 1024x768 photo into 320 x 240 TFT LCD ?
thanks
A lot of software can do this:
Photoshop
Paint.NET
MS Paint
If that is nor what you are looking for, then please be specific about what hardware the resizing will run on, what operating system (if any), if this is to be incorporated into some firmware and if so what programming language used etc etc..
I want to shrink the photo from sdcard with the MCU not with PC...
Since you made no specification of the other circumstances I asked for: OK. Bye.
1024 / 320 (and 768 / 240) is 3.2
So you need to take the colour information from a 3.2 by 3.2 grid of pixels to make a single pixel in the output image.
Of course 0.2 of a pixel is quite a tricky concept ;-)
One simple technique would simply be to just use 3x3 grids of pixels but 1024x768 divided by 3 is 341x256 which is a little larger than your 320x240 display area.
If you were willing to simply crop and lose the edges then this might be workable still. In the X there are 21 too many pixels and in the Y there are 16 too many. So start the equivalent of ( 10,8 ) into the picture which, because of the /3 is (30,24).
IF you really want a /3.2 scaling you will likely want to employ error diffusion. A simple technique is Floyd-Steinberg.
One thing to bear in mind is how much CPU time you are willing to dedicate to this task. If these are just to show "thumbnails" of the larger images statically you can take a second or two do the scaling and no one will probably mind too much. If however these were frames of animation to be shown at 5 to 10 frames per second the time you have available to scale is much much less and you may need to make compromises.
One very simply compromise is that /4 on a binary computer is MUCH easier than /3. So if you were willing to scale the pictures to 1/4 their size (that is 1024x768 -> 256x192) then you could simply average 4x4 grids of source pixels.
For each output pixel you go 4 across and 4 down adding up the colour values of 16 pixels then divide the sum by 16. Watch for integer overflow but note that a /16 can even be easier than a /2 or /4 in some cases as it can involve nybble swaps.
Also consider whether this is mono or colour and how many bits per pixel there are either for the Y or the RGB.
You need to divide the image into blocks of 3.2 * 3.2 pixels, find the average colour value for each block. How you actually do that is up to you, and depends on how much memory you have available and how much time you want to spend on it(both your time and the AVRs time).
Let's say you want the top left pixel of your 320 * 240 image: For each of R, G and B, add the values of the first three pixels on the top row of the larger display, then add 0.2 of the value of the next pixel. Repeat for the 1st three pixels of the next 2 rows. Finally, add in 0.2 of the value of the first 3 pixels on the 4th row, and then 0.4 of the 4th pixel on the 4th row. Now find the average by dividing all the sums(R, G and B) by 3.2. When you move to the next block, things will be more complicated, as now you need 0.8 of the first values and 0.4 of the last. You get the idea. It will be horribly slow.
If you have sufficient memory, you could duplicate each pixel of the larger image 4 times, so that you have 5 of each. Then you can average 16 by 16 pixel blocks of this extra large image.
Maybe there's an easier way, but I can't think of it right now.
Much simpler to take Johan's advice and do it on the PC first. Added to which you only need a tenth of the memory space to store a 320 * 240 image.
Must learn to type faster.....
Two really good messages to add to the image processing algos examples directory. Where was that again?
Right there at the place where you created it, Bob..
To clawson, thank you for the explaination, I'll try to understand and translate it into code...
I saw this one :
http://tech-algorithm.com/articles/nearest-neighbor-image-scaling/
Can I use it ? any experiences ?
thanks
[url][/url]
I have made this far, but I need to convert to 320x240 in PC first before I can use the picture with this code (on MCU), please have a look, thank you
//Function reading 262K file
  void LCD_BMP_reading_shrink(char filename[120])
     char temp_buffer[100],line[512];
	int count,z,bmpData,bmpAddr;
	int x = 0;
	int i,y = 0;
	int xx, yy;
    uint8_t hdr[0x28];
	UINT bytesread;
    uint8_t hdr_256[0x36];
    static uint16_t w[256];
    uint32_t off;
	 res = f_open(&fsrc, filename, FA_READ);
						  f_read(&fsrc, hdr_256, sizeof(hdr_256), &bytesread); // Read header
						  off = *((uint32_t *)&hdr_256[0x0A]); // offset to rasters
						  xx = *((uint32_t *)&hdr_256[0x12]); // X pixels
						  yy = *((uint32_t *)&hdr_256[0x16]); // Y pixels
						  f_lseek(&fsrc, off); // Seek to the data
						  for(y=0; y> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3);
						      LCD_SetPoint(y, x, rgb);
						    } // x
						  } // y
						  f_close(&fsrc);
3.2 px isn't that hard.
Your image is 1024 x 768.
To figure each pixel of your 320x240 image, average the r, g and b's of a 4x4 pixel area of the original image.
The trick is in deciding which 16 source pixels to use for each dest pixel. Just take the dest pixel position, multiply it by 3.2 and truncate to find the source pixel position. Or, as I'm want to do to avoid floating point, add 32 and divide by 10.
Petulantly yours
if you want it quick just take pixel :
0,3,6,9,12,16,19,22,25,28,32 (every 5'th time add 4 else 3) make it with a counter or use that 3.2 is 16/5
in both x and y direction and forget about the rest of the pixels
if you want it a tad better do the same but use the pixels next to it as well. direct as a sum and div by 9 or something like this:
20 30 20
30 56 30
20 30 20
and then div with 256 same as move a byte (>>8 )
Way cool. Its like auditing a 5000 level class in image processing.
Multiplying by 32 might be better...
If you're doing the conversion on the PC then, surely, there are plenty of PC image manipulation tools to do that :?:
It is, and I want to convert it inside MCU, thanks guys for the suggestions, I'll give a try...
I'll get back after I've tried with the code..
Like this ?
for(y=0; y
Like this ?
But that doesn't implement the algorithm sparrow2 suggested? He said that instead of incrementing +3, +3, +3, +3, +3, +3... you should increment +3, +3, +3, +3, +4, +3... so that every 5th increment is 3+1. Perhaps the easiest way to achieve that is
int n;
for(x=0, n=0; x
I'd be tempted to call your "xx" something like "w" or "width". Having both x and xx variables makes the code confusing and difficult to read. ("yy" = "h"/"height" too).
int n;
for(x=0, n=0; x
do I need
int n;
for(y=0, n=0; y
as well ?
That was the plan, yes.
There are two ways to do this.
1) Either just pick up every 3rd/4th pixel and use that - this is the very quick method suggested by sparrow2
or
2) combine methods: use the 3/4 stepping but also sum/average a complete 3x3 or 4x4 grid at each step
One thing I wouldn't do is develop this on an AVR. I'd write a small C program in Windows that can bitblt() the result to a client window area and see what actually works OK. Does the 3/4 step ignoring all other pixels look OK or do you need to use the 3x3/4x4 averaged grid method? Also just getting the grids/steps right is much easier if you can instantly visualise the results on a PC. One technique I've used in the past is to display both source and destination images. Have some form of user input so you can step across the X or down the Y to see the result being built and also, to make sure you are using the right source pixels each time, having read the source write back to your stored copy and display it - turning the pixels you just read to red or green or something. That way you can see if you are inadvertently overlapping your source squares/rectangles or anything like that.
(actually this is such an interesting challenge I might try it myself).
Obviously if you develop it on a PC you should find (if you stick with stdint.h types) that you can just build the same code for an AVR and it will work there too.
That leads to another possibility. I'll bet you aren't the first person who ever wanted to scaled 1024x768 to 320x240 so I'll bet there's code out there on the net already doing this. Pick it up, build it for your PC display program, when that works take the algorithm code to your AVR where you know it works and any other "wrong display" problems are something else and not a fault in the scaling code as such.
EDIT: actually I typed "scale 1024x768 to 320x240 code" into Google and the top hit was this thread- maybe you are the first??
I've tried to shrink stuff down and the problem with just copying every 4th pix to the dest frame is that lines that are 1 pix wide and not on that magic 4pix boundary dont get copied. They just disappear. So the average trick is needed.
How does the 1024x768 get written to the sd card? Why cant it get shrunk to 320x240 before writing? I like to try to visualize the gizmo in use.
I totally agree, Bob. Some sort of averaging is needed.
I think maybe Torby had the best solution yet that trades off speed and accuracy in his post I quote below puctuation what do I care for punctuation.
The downside of such a method is that some pixels will have more "influence" than others, but I doubt that it'll be that noticeable.
Petulantly yours
Does anyone have experience of the Win32 LoadImage() API?
I am trying:
   case IDM_FOPEN:
	    OPENFILENAME ofn;
	    char szFileName[MAX_PATH] = "";
	    ZeroMemory(&ofn, sizeof(ofn));
	    ofn.lStructSize = sizeof(ofn);
	    ofn.hwndOwner = hwnd;
	    ofn.lpstrFilter = "BitmapFiles (*.bmp)\0*.bmp\0All Files (*.*)\0*.*\0";
	    ofn.lpstrFile = szFileName;
	    ofn.nMaxFile = MAX_PATH;
	    ofn.Flags = OFN_EXPLORER | OFN_FILEMUSTEXIST | OFN_HIDEREADONLY;
	    ofn.lpstrDefExt = "bmp";
	    if(GetOpenFileName(&ofn))
             MessageBox(hwnd, szFileName, "Filename", MB_OK);
             bmpFILE = LoadImage(NULL, szFileName, IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE);
The MessageBox confirms that the BMP file I just chose is the correct one but after the LoadImage the bmpFILE (which is an HBITMAP - don't ask!) is always NULL?! I don't need anything more than LR_LOADFROMFILE in the fuLoad parameter do I?
I need to add:
For a good result avoid using jpeg pictures those "false" edges will make it look kind of odd.
Just to note that after a bit of googling I found others who got NULL from LoadImage() and yet GetLastError() also gave 0. In both cases they simply loaded the .BMP into Windows Paint then saved it again and that fixed things. That worked for me too. I had initially resized/cropped the image I was trying to use with Gimp and while it was usable as a 24bit RGB BMP in most places LoadImage() didn't like it.
I also found that I'd forgotten to InvalidateRect() to force a WM_PAINT to get it drawn on the client area. So now fixed and I can load and display a 1024x768 image so now to try scaling it....
Does Mr Bianchi have an example bmp? Is it rgb? A photo? Graphics?
The 1024x768 I'm using:
Whats all those white specs in the eyes? Rooting in the garden for moles?
This is probably obvious, but perhaps worth mentioning.
If one is looking for 1 pixel wide lines, and doing a four pixel average for compression, then the threshold for calling the pixel ON is >= 25 %, (assuming a blank background, etc.). Hence in practice one might set the threshold quite low.
The nice thing about doing the test program on a PC is that one could have a slider for the threshold to call a pixel On/Off, and watch the lines appear / disappear as one moves the threshold slider.
Good point. When taking advice from a dyslexic brat, always check his math.
I tried :
	  //262K picture
                        delay_ms(1500);
	 res = f_open(&fsrc, "test31.bmp", FA_READ);
 f_read(&fsrc, hdr_256, sizeof(hdr_256),&bytesread); // Read header
						 for(y=0, n=0; y> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3);
								    } // x
						  } // y
						  f_close(&fsrc);
						  delay_ms(2000);
Please correct me if I missed something here, thanks
I'd like to see the picture unless its a picture of your girlfriends hoohoo.
I got a picture already, but not yet right...
I apologise on behalf of Bob.
The correct term, so my daughter, who is a trained nurse, informs me, is "floo floo".
I had assumed that the OP was using a colour display.
Yes it's 262K colour display,
I want to display :
on LCD I have :
I used this function for displaying it,
   //262K picture
                        delay_ms(1500);
                            } // x
                    } // y
                    f_close(&fsrc);
                    delay_ms(2000);
Any clues guys ?
thanks
First thing I notice is that you're using the same variable, n, in both the outer loop(y) and the inner loop(x). This is surely not going to work.
And you're using the same x and y, unless I'm mistaken, for both the 1024 by 768 and the 320 by 240.
How much RAM do you have available for this task?
so I have to separate the variable ?can you give me a clue in code ? RAM inside LCD is 191 Kbytes
//262K picture
uint16_t destx;
uint16_t desty;
delay_ms(1500);
sourcewidth = *((uint32_t *)&hdr_256[0x12]); // X pixels
sourceheight = *((uint32_t *)&hdr_256[0x16]); // Y pixels
destx = 0;
desty = 0;
for(y = 0, ny = 0; y < sourceheight; ny += 3, ny++)
	if (ny == 5)
		y++;
		ny = 0;
	for(x = 0,nx = 0; x < sourcewidth; x += 3,nx++)
		uint32_t rgb;
		if (nx == 5)
			x++;
			nx = 0;
		f_read(&fsrc, &rgb, 3, &bytesread); // Read pixel B G R
		// RRRRRRRRGGGGGGGGBBBBBBBB 8:8:8
		//         RRRRRGGGGGGBBBBB 5:6:5
		rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3);
		LCD_SetPoint(desty, destx, rgb);
		destx++;
		if(destx == 320)
			destx = 0;
			desty++;
f_close(&fsrc);
delay_ms(2000);
Something like this(untested)
And I meant how much RAM for the code to use. Because once you find out how crappy it looks taking every 3rd pixel, you'll be wanting to do some averaging, and there might be faster ways of doing that if you have a few K of RAM available.
I'll offer my opinion that a screen full of blue pixels is not the most detailed test pattern for a reduction algorithm. How can you tell if the row and column you want to see is accidentally deleted? That's why I asked what your test picture was. I will also offer my idea that if I had to do this, I would open the file, read 4 lines of the picture to ram, walk the 4x4 averager/filter across the line, writing the resulting 320 pix for the dest frame to the sd card. Repeat 240 times. Read 320x240 image back from sdcard to lcd. Whew. Lots of work.
The kinda official way to downsize an image is to low pass filter the complete image and *then* to decimate it. The thing that needs to happen is that the averager (if that's your chosen filter) should not just filter the four lines you're trying to compress into one, but should include the lines to either side.
If you don't average, you *will* get alias 'jaggies' in the final image. Whether this is acceptable can only be decided by you, but such images look excessively edgy and high-frequencies are incorrectly emphasised by the aliasing.
Because your divide ratio is not an exact integer (unless you slice part of the image away to make it exact) you'll still get jaggies if you use the naive 4-4-4-5-4-4-4-5 sampling - again, your decision as to whether that is acceptable.
The clean way to arbitrarily down-scale an image is to upscale it first - insert zeros between the original picture pixels - until it's a size that shares a common multiple with the final image (e.g. if you're going to 7/8ths the original size, you'd upscale by a factor of 7) and then low pass filter the result to leave no alias frequencies. Then decimate the image for the final image - in this case, take every eighth pixel.
That's obviously incredibly time consuming though there are optimisations that help with the filtering, and it takes a lot of memory... sometimes you just have to be pragmatic.
I got :
with this function :
			destx = 0;
			desty = 0;
			   if (ny == 5)
			      y++;
			      ny = 0;
			      uint32_t rgb;
			      if (nx == 5)
			         x++;
			         nx = 0;
			      destx++;
			      if(destx == 320)
			         destx = 0;
			         desty++;
				f_close(&fsrc);
what do I miss here ? thanks
Doremon - i'm more of a Hello Kitty fan. Oh, you mean the lcd..... I would normally use printf to dump out the loop values. You should see a pattern.
probably like this ?
 printf("Dest y : ");printf(desty);NEXT_LINE;
 printf("Dest x : ");printf(destx);NEXT_LINE;
  printf("rgb : ");printf(rgb);NEXT_LINE;
printf(desty);
No. The variable desty does not contain a format string. In fact, it is not even a string - it is an integer value.
which leads to
where it is written
The format string is composed of zero or more directives: ordinary characters (not %), which are copied unchanged to the output stream; and conversion specifications, each of which results in fetching zero or more subsequent arguments.
Or just read about printf in your C textbook.
Same for destx and RGB.
should be
for(y = 0, ny = 0; y < sourceheight; y += 3, ny++)
My typo. Sorry.
should be
My typo. Sorry.
Ok,
I'll try, thanks
I made :
	int x = 0;
	int i,y = 0;
	int xx, yy,ny,nx;
    uint8_t hdr[0x28];
	UINT bytesread;
    uint32_t off,sourcewidth,sourceheight;
			    //262K picture
			uint16_t destx;
			uint16_t desty;
			delay_ms(1500);
			 LCD_Clear(Black);
			destx = 0;
			desty = 0;
//for(y = 0, ny = 0; y < sourceheight; ny += 3, ny++)
			   if (ny == 5)
			      y++;
			      ny = 0;
			      uint32_t rgb;
			      if (nx == 5)
			         x++;
			         nx = 0;
				  destx++;
			      if(destx == 320)
			         destx = 0;
			         desty++;
				f_close(&fsrc);
				delay_ms(2000);
I got :
Please let me know what I miss here ?
thanks
Although you are counting to every third pixel, you are just reading consecutive pixels from the large image. You need to either read and discard all the intermediate pixels, or fseek to the one you want. I have no idea as to which would be quicker, but with the code as it is, it would probably be easier to use the x and y values to calculate a new offset in the file to fseek to.
So every time you read the rgb values from the file you need to to calulate the offset within the file.
Have a new variable, pixeloffs, and do something like
pixeloff = offs + (y * 1024 * 3) + (x * 3); // Assuming three bytes per pixel
f_lseek(&fsrc, off); // Seek to the desired pixel
Note that this works because the big image width is 1024. If it was some other width, you would need to work out the row size, as I believe rows are padded to be multiples of 4(?) bytes.
hmm.....try to understand...I'll get back later..thanks
f_lseek(&fsrc, pixeloff); // Seek to the desired pixel
Edit: Corrected line above, the seek is to pixeloff, not offs.
then display those pixels into the LCD with LCD_Setpoint ? thanks
I hate to ask this lo level question, but we have to assume the drawing stuff works well and you can draw a box around the lcd and two vertical lines on the left and they actually show up as vertical lines on the left, not right, not horizontal, not diagonal? OK, good. Now we can use the lcd to look at the picture. How about cooking up a 320x240 bmp and test reading that? Looks ok? Great. I'd try 640x480 next.
I had a chance to work a bit more on my Windows program to try various types of scaling but stopped after the first attempt because to these tired old eyes it actually looks pretty bloomin good without bothering to explore other options. This is the scaling I used:
    if (dispBmp) {
	    MemDCFILE = CreateCompatibleDC(hDC);
	    SelectObject(MemDCFILE, dispBmp );
		if (scaled != TRUE) {
		    GetObject( dispBmp, sizeof(BITMAP), &bm );
		    BitBlt( hDC, 10, 10, bm.bmWidth, bm.bmHeight, MemDCFILE, 0, 0, SRCCOPY );
		else {
            HBITMAP hNewBmp;
			HDC hEditDC;
			int x,y;
            hNewBmp = CreateCompatibleBitmap(GetDC(hwnd), 320, 240);
			hEditDC = CreateCompatibleDC(GetDC(hwnd));
			SelectObject(hEditDC, hNewBmp);
			for (y=0; y<240; y++) {
				for (x=0; x<320; x++) {
					SetPixel(hEditDC, x, y, GetPixel(MemDCFILE, x * 3.2, y * 3.2));
		    BitBlt( hDC, 10, 10, 320, 240, hEditDC, 0, 0, SRCCOPY );
            DeleteObject(hNewBmp);
			DeleteDC(hEditDC);
        DeleteDC(MemDCFILE);
    EndPaint(hwnd, &ps);
As you can see all I do is step x,y for the dimensions of the destination image and set the output pixel (SetPixel()) to the pixel at GetPixel(x*3.2, y*3.2) from the source image.
As I say the result looks pretty darned good to me... though I suppose some of Amelia's more vertical whiskers have disappeared a bit?
For completeness I may try the 3,3,3,3,4... thing and also 3x3 or 4x4 averaged grids but, to be honest I don't see a lot of point.
Of course this "costs" a "* 3.2" operation but that doesn't matter on this multi-GHz PC ;-)
If anyone's interested I can upload the complete Pelles C project that created this Windows application.
That is suprisingly good.
So when a user mode app in windows calls the setpixel() sub in the linked in runtime lib, it calls a sub pointed to in the graphics driver, could be directx (whatever that is), GDI, the driver in the firmware of the graphics card. It could be doing some sort of antialiasing/smoothing/texturing. Who knows whats going on. Who even knows how many layers of api there are?
To Clawson, I wish I can do
on my code...
I wish...
no problem with 320x240, if I create first on PC and then copy to SD card,
have a look..
https://www.youtube.com/watch?v=P_Bvq7yXxIk
thanks
To John,
						  pixeloff = off + (y * 1024 * 3) + (x * 3); // Assuming three bytes per pixel
it's "off" not "offs", isn't it ?
thanks
Yes.
John_A_Brown wrote:
Yes.
I have tried it, still the same, no luck :( ....
Post your actual code.
Hi John,
Here's the code I used, please have a look and correct me if there's mistake, thanks
	int x = 0;
	int i,y = 0;
	int xx, yy,ny,nx;
    uint8_t hdr[0x28];
	UINT bytesread;
    uint32_t off,sourcewidth,sourceheight,pixeloff;
			    //262K picture
			uint16_t destx;
			uint16_t desty;
              delay_ms(1500);			             LCD_Clear(Black);
//f_lseek(&fsrc, off); // Seek to the data
destx = 0;
desty = 0;
			   if (ny == 5)
			      y++;
			      ny = 0;
			      uint32_t rgb;
			      if (nx == 5)
			         x++;
			         nx = 0;
				  //sprintf(temp_buffer,"%.2d",rgb);printf(temp_buffer);printf("\n");
				  destx++;
			      if(destx == 320)
			         destx = 0;
			         desty++;
				f_close(&fsrc);
				delay_ms(2000);
trying to fix identation, it's ok on my compiler... but change if I copy here....different size
 int x = 0;
   int i,y = 0;
   int xx, yy,ny,nx;
    uint8_t hdr[0x28];
   UINT bytesread;
             //262K picture
         uint16_t destx;
         uint16_t desty;
         delay_ms(1500);
          LCD_Clear(Black);
         f_lseek(&fsrc, off); // Seek to the start of the pixel data
         destx = 0;
         desty = 0;
            if (ny == 5)
               y++;
               ny = 0;
               uint32_t rgb;
               if (nx == 5)
                  x++;
                  nx = 0;
              destx++;
               if(destx == 320)
                  destx = 0;
                  desty++;
            f_close(&fsrc);
            delay_ms(2000);
But one more question. What display are you using? Does it have the abilty to auto-increment to the next pixel? All the 320 by 240 displays I've used have this function.
Dangit, John.. Bianchi got the indentation (almost) right for once, and immediately you ruin it.. :wink:
That's because I copied and pasted his code into a text editor to modify it. The weird mixture of tabs and spaces creates massive chaos. I have a proper job to do and I can't be arsed to straighten it up.
If you look at the code I posted on the 26th at 12:56 you'll see that I did attempt to get the formatting right(for my preferred scheme) but it was back to usual with the next post from the OP, and complete with variable names like xx and yy.
John
I don't know if it does,
It's SSD1289 320x240 262K colours
A quick look at the datasheet reveals that it does.
To John,
There's a progress
I followed the code :
	int x = 0;
	int i,y = 0;
	int ny,nx;
    uint8_t hdr[0x28];
	UINT bytesread;
			    //262K picture
			uint16_t destx;
			uint16_t desty;
			delay_ms(1500);
			 LCD_Clear(Black);
			destx = 0;
			desty = 0;
			   if (ny == 5)
			      y++;
			      ny = 0;
			      uint32_t rgb;
			      if (nx == 5)
			         x++;
			         nx = 0;
				  destx++;
			      if(destx == 320)
			         destx = 0;
			         desty++;
				f_close(&fsrc);
				delay_ms(2000);
Please let me know what do I miss here ? thanks
I tried another one :
on LCD :
It's diagonal, why is it ?
Is this correct? It is, I think, more usual for x to be first:
i.e.
LCD_SetPoint(destx, desty, rgb);
However, it looks to me as though something is out by a factor of two.
Bob the functions I use are GDI from the WIN32 API. It is possibly one of the best documented programming APIs on planet earth:
http://msdn.microsoft.com/en-us/...
There is nothing "hidden" in the driver or what it does. If Microsoft says it sets a pixel to COLOREF on a bitmap selected into a device context then it sets a pixel in a device context - nothing more.
I fear you aren't getting the point of my posts and my small example program. There is nothing on earth stopping you doing the exact equivalent of:
In fact, you probably don't even need to pass a pointer to a device context/memory buffer as you aren't going to be working on lots of them. As for implementing GetPixel(x,y). Yes I know you only have a 512 byte sector buffer for the file read and yes, it may take some time to work out where in a file pixel (x,y) is then fseek() to that place and fread() the data (if you are lucky it's in the same sector you just read and will be buffered anyway - especially if you work across the X) but I would not try to do everything in huge cascades of nested for(x)/for(y) loops. Instead I would implement a GetPixel() and simply make sure that when you GetPixel(123,456) it really does return the colour of the pixel at that location. Similarly I would implement SetPixel() and then the conversion really does become as simple as:
Now I'll agree that this is not efficient code but it lets you work on the high-level design of the function. You can try other techniques for gathering the source pixels (and possibly averaging) and see how the results look. When you have found the "best looking" solution you now begin to look at optimisations for it that work best in a 512 byte sector buffer in the limited RAM of an AVR.
But do the high level design work first. Oh and did I mention that it would be 10 times easier to work on this in a PC program than on the limited resource hardware of an AVR?
BTW when you think about what my code is doing:
it will be:
x      0    1    2    3    4    5    6    7    8    9    10
x*3.2  0    3.2  6.4  9.6  12.8 16  19.2  22.4 25.6 28.8 32
int(N) 0    3    6    9    12   16  19    22   25   28   32
+N     0    +3   +3   +3   +3   +4  +3    +3   +3   +3   +4 ...
So (I guess I'm a bit slow!) this IS just implementing the 3,3,3,3,4,3,3,3,3,4... pattern. As such the AVR does NOT need to do floating point "* 3.2" operations. Just doing the sourceX+3 thing with N==5 leading to sourceX+3+1 would have the same effect.
Of course now I have my basic GetPixel and SetPixel I can try replacing the *3.2 stuff with exactly that to verify that the integer version leads to the same result (it will).
Hmm..
Should it be N == 4 ?
Although I don't see how that would have the observed effect.
i.e.
yea, that's correct, because if I reverse it, I have a reversed picture...
John_A_Brown wrote:
Hmm..
I'll give a try and see what happens
thanks
 if (ny == 5) and  if (nx == 5)
try with if (ny == 4) and if (nx == 4) ?
There are four blue stripes on diagonal now....I'm not sure it's from there...?
Are you 100% sure that the image you are using is 1024 by 768?
100% sure for the size, it is 1024 by 768...something missing on the code ? thanks
BTW I changed my code to use the integer version of 33334 stepping:
HBITMAP hNewBmp;
HDC hEditDC;
int x, y, n, m, destx, desty;
n = 0;
m = 0;
destx = 0;
desty = 0;
for (y=0; y<768; y+=3) {
	for (x=0; x<1024; x+=3) {
		SetPixel(hEditDC, destx, desty, GetPixel(MemDCFILE, x, y));
		destx++;
		m++;
		if (m == 5) {
			x++;
			m =0;
	destx = 0;
	desty++;
	n++;
	if (n == 5) {
		y++;
		n = 0;
DeleteDC(hEditDC);
and the visual result was identical.
The structure of this is very similar to what you are attempting except that I post increment n/m whereas you pre-increment.
Another thought about your data - what file format is it? If 24 bit RGB BMP and accessing the pixel data directly then apart from the obvious "upside down thing" in Windows BMP remember about the padding to 32 bit boundary though I would have thought 1024 wide images hit this naturally anyway as 1024 * 3 is 3072 and 3072 / 4 is 768 which is an integer multiple.
to clawson,
I don't understand...how to relate it with my code ?
It's 24 bit BMP RGB 1024x768
You use:
I chose not to mix the n/m stuff in with the outer for() loops (though I guess I could have) and in your code sourceheight=768 and sourcewidth=1204 so your loops really say:
for(y = 0,; y < 768; y += 3)
       for(x = 0; x <1024; x += 3)
Unless you can spot it I think we have identical code in this sense.
Yup I realised that from studying your code some more (I did find hdr_256 to be quite a confusing name though!)
I took a 320 by 240 image, displayed it on my LCD, then displayed a scaled version(works out at 100 by 75).
This is what it looks like. Sorry about the terrible photo, it's just a crappy phone camera picture, and there's some sort of moire pattern artifact going on. It actually looks pretty good in real life.
The scaled image is upside down, you say? Yes, it is. On the big picture I read the bitmap backwards, as Windows saves from the bottom up. On the scaled image, I didn't want to complicate things that much.
void ScaleIt(uint32_t FlashAddr)
uint8_t buffer[64];
uint32_t FileSize;
uint32_t BitmapOffset;
uint32_t BitmapWidth;
uint32_t BitmapHeight;
uint32_t RowSize;
uint32_t colour;
uint32_t scalex, scaley;
uint32_t pixeloffs;
TFT_SetBotRight(319,240);
DataFlashReadBlock(FlashAddr, buffer, 64);		// Read the header info
FileSize = (buffer[2]) | (buffer[3] << 8) | (buffer[4] << 16) | (buffer[5] << 24); // Get the file size
BitmapOffset = (buffer[10]) | (buffer[11] << 8) | (buffer[12] << 16) | (buffer[13] << 24);	// Get the offset to pixel data
BitmapWidth = (buffer[18]) | (buffer[19] << 8) | (buffer[20] << 16) | (buffer[21] << 24);   // Get the bitmap width
BitmapHeight = (buffer[22]) | (buffer[23] << 8) | (buffer[24] << 16) | (buffer[25] << 24);  // and the height
RowSize = ((24 * BitmapWidth + 31) / 32) * 4;			// Work out the row size
for(scaley = 0; scaley < 75; scaley++)
	for(scalex = 0;scalex < 100; scalex++)
		pixeloffs = BitmapOffset + ( (scaley * 32 / 10) * RowSize) + (scalex * 32 / 10) * 3;
		TFT_SetTopLeft(scalex, scaley);
		DataFlashReadBlock(pixeloffs, &colour, 3);
		TFT_WritePixel(colour);
My bitmpap is simply stored in a flash chip, rather than being part of a filing system, but the general principle is the same.
And the reason I didn't start out with 1024 by 768 is that my Flash chip isn't quite big enough.
It works already, thanks guys..
Already?
:D
And you shrunken image looks nice?
John_A_Brown wrote:
Already?
:D
Yes it did, thanks
Yes it does,
have a look on youtube, after the green and white box are 1024x768 shrunken
https://www.youtube.com/watch?v=P3rlm3_uV0k
Interesting background music choice - thank goodness it doesn't sound like a 70's porn video...
.. oh wait a minute!
AVR digital picture frame. Perhaps it should appear on hackaday?
Bianchi77, we want to know what you did that finally fixed your image shrinking code!
You haven't figured out bianchi77's M.O. yet, John?
Obviously not.
I don't think I'll be helping him/her again.
