8 bit encoder interface
6 posts / 0 new
Greetings EveryBody!
I am trying to interface an 8-bit absolute encoder (datasheet attached) with ATMEGA16.
I am trying to read values so that I tried several web links and I searched on the google even but could not find the good way.
Kindly guide me a way how to do ths.
Many Thanks for your kind consideration.
No it isn't. But irrespective of that, what have YOU actually done apart from searching for ready made code?
Sorry mistakenly I didnt attach datasheet but now attached in the first one.
secondly i have'nt done anything. I just want to understand the position of the encoder but as I am using 8 bit so it would have 256 positions (means 256 separate codes) would i have to define 256 different codes in AVR for position detection?
I have looked at the table in the data sheet and see no obvious computable correspondence between position and value output. It seems to me that you need to have a lookup table (LUT) to translate between the output value and position.
E.g. something like
uint8_t position_table[256] = {
   0,    // Output value 0 is not used
   56,   // Output value 1 corresponds to position 56
   40,   // Output value 2 corresponds to position 40
   55,   // Output value 3 corresponds to position 40
   24,   // Output value 4 corresponds to position 24
   0,    // Output value 5 is not used
   39,   // Output value 6 corresponds to position 39
  112,   // Output value 254 corresponds to position 112
    0,   // Output value 255 is not used
The usage is easy. Assuming you have the eight pins of the encode attached to PINB you simply
uint8_t position = position_table[PINB];
To not waste RAM you might put this table in flash.
GOOGLE: bourns ace
http://www.piclist.com/techref/p...
http://www.krafti.co.uk/steve/bo...
Even if we don't like it, we can share code from PICs
Many thanks to all of you, Your replies and your kind considerations are very helpful.
