A code structure problem
8 posts / 0 new
Greetings -
I have an application that accepts a variety of serial input ASCII characters as "commands". For example, M,U,u,P,?,D,S. The list makes up much less than half of the ASCII character set (13 at latest count, might go slightly higher).
Each message begins with a '$' as a "framing" character, then one of the characters, above. I would like to test whether or not the received character is one of the 13 valid characters.
A chain of if(), else if(),.. would work but that seems awkward. A switch chain would also work but, again, its just big enough to seem awkward. There are too many to do if(MyChar == 'M")||(MyChar == 'U')|| ...
Unfortunately, the list is quasi-random with little in common between them beyond the fact that they are ASCII characters.
So, is there any way to simplify this process, somehow?
One vote for switch() here.
A switch block is not that untidy:
    switch (c) {
    case 'M: case 'U': case 'u':
        return TRUE;
    default:
        return FALSE;
OTOH, just put all your valid characters in a string.
I would assume that NUL is not a valid command.
    char validchars[] = "MUuP?DS";
    for (char *p = validchars; *p != NUL; p++) {
        if (*p == c) return TRUE;
    return FALSE;
You normally want to know which command:
    for (int i = 0; validchars[i] != NUL; i++) {
        if (validchars[i] == c) return i;
    return -1;
Oh, I had forgotten about multiple cases on a line!
I like that.
You made it harder on yourself. :twisted:. If you'd restrict yourself to e.g. the alphabet and case-insensitive then you could make a bit mask and ...
But yes, these "little languages" seem to grow on their own.
{AFAICR] The lex/flex state machine approach is proven to be most efficient. That may well break down with your "little language". (I used that phrase purposefully as there is lots of literature on these.)
In practice, I generally use a state machine. It depends on the structure of the rest of your sentences. Sometimes I go character-by-character with a timeout if a complete sentence is not received in time (following the starting trigger). Other times, if e.g. the sentence ends with a carriage return I'll process in one sweep.
If you have 256 bytes of program-space left
simply use a table that maps the character to some
number you want.
myNewCode=theTable[theCharacter]
Setup the table at compiletime in pgmspace
They don't have to be one line; eg,
switch( c )
   case 'a':
   case 'S':
   case 'd':
   case 'F': whatever();
             break;
   default:  other();
             break;
Which makes it very easy to create - just copy & paste as many blank 'case' lines as you need:
   case '':
   case '':
   case '':
   case '':
Then go through putting in the characters.
8)
This is a bit of c that I don't remember ever learning about in the pre-1999 world.
Then, again, it may just be be the "fog of time". Glad that I know about it now. I like it.
