AVR reseting problemmo!
2 posts / 0 new
I had this piece of code in my AVR, and it ALWAYS reset the AVR.
mame_stack is a unsigned char set by a interrupt
temp_w1 unsigned int, with initial value of 0
wdt_reset is just for the efect, wd is not actualy enabled...
while((mame_stack != 1) || (temp_w1++ != 65530)) wdt_reset();
My question:
Could the reset be caused by incrementing temp_w1 over 0xFFFF? (buffer overflow)
Why did the reset happen? When I deleted this line all was OK![/i]
1. 0xFFFF is decimal 65535 (not 65530).
2. If I'm not misreading Your code completely: The condition for the while statement is written so that whenever temp_w1++ is != 65530 a call will be made to wdt_reset(). If You initialize temp_w1 to 0 (zero) the increment operator will give it the value 1, and that certainly is != 65530 and so wdt_reset() will be called.
