AS6 Output Files
3 posts / 0 new
Quick question folks,
When a project/solution is built in AS6 a number of output files are generated in addition to the hex file.
Is there are scenario where the firmware should be flashed with a file other than the hex file? For instance when it is being deployed as opposed to debug??
Cheers
Ade
AS6, GCC, XMega128A3U
You might use elf rather than hex if you want a single file containing code, eeprom, fuses, lock bits.
Otherwise always use hex for code and eep file for eeprom.
thanks WrightFlyer.
