increasing pwm resolution
5 posts / 0 new
Hello
I am using the tiny26 with approx 8 bit pwm resoution (25KHz PWM, 8MHz clock). I am interested in increasing the resolution up to 10 bits. Are there any tricks that have been tried or might work?. It seems that some secondary interrupt manipulating (dithering) the 8 bit pwm value settings (say at 100Khz) might give a little better (average) resolution.
any thoughts or examples of this technique?
Hoyt
Seems like if you just used the timer compare int to increment tics, reset the pwm out every 1024 tics, turn it on when tics=pwm value, you could do the pwm in sw and have any number of bits.
Someone here earlier mentioned a clever idea, using two pwm channels
with outputs summed together in a weighted fashion. This method can
be used to increase resolution and/or frequency.
Tom Pappano
Tulsa, Oklahoma
Tom Pappano
Tulsa, Oklahoma
Thanks Bob-
I certainly could try a software approach, except that I want to use the non-overlapping pwm mode (which could still be done in software, tho more complicated) & most imporatantly I need 25Khz. At that rate there is a lot of software time being "burned up"...compared to "none" used by the pure hardware pwm generator.
In fact, I had been thinking about my original post & realized that I want to dither the pwm value at a LOW freq, say 2KHz. This is much less of a software load. Say 'm at a nominal 8bit 25KHz pwm value of "155". At 1 khz I could change the value to this sequence: 155, 155, 155, 156 & repeat. Or 155, 156,155,156, repeat. Thus the average PWM resolution would be increaed by 2 bits. Since I'm running a motor it will apply an advanced smoothing algorithm (its inertia) My only concern is the generation of a beat frequency, but I'll have to investigate this.
Time for some code!
this is akin to divide by N ... divide by ( N+1) strategy used in PLL design.. it ought to work
