Hello, I just received 5 LM35DZ temperature sensors. I was quite happy till I tested them and saw that the output voltage doesn't make sense. I powered them with 5 volts and the output is 4.14V in all of them. The temperature is around 20 degrees. As far as I know the Vout should be around 0.2V at this temperature(20*10mV).
Did I buy garbage or someone has any different idea?
