If you have a tool that seems to be working differently to everyone else then surely the first thing you do is check that you have the latest (with the most bug fixes). Report back when you have 6.2.993 (Beta).
Well there's a lesson to be learned here - if something doesn't work ALWAYS check first that you have everything up to date - otherwise, nine times out of ten, you are simply rediscovering a bug found/fixed 3 years ago.
Lee,
Sorry to be a pain in the ass.
I do not know which version you are referring to. I thought it was what I tested. The only other C source I posted was the original program.
Please post what you would like me to test and I will.
Sorry for the confusion.
I'm using Version 6.0 build 1841
Top???
Link to your posted program:
No superfluous crap in the ISR. A double-set of the I bit during init but that shouldn't be a problem.
TopOh dear God - then what do you expect?!?
TopCliff,
Sorry, I figured if I posted this info halfway into the thread and no one flamed me, It wasn't an issue.
I will do as suggested and get back to you.
A.
TopCliff / Lee,
All is right with the world.
A current version of AS6 corrected the problem.
Thanks to you both.
A.
TopWell there's a lesson to be learned here - if something doesn't work ALWAYS check first that you have everything up to date - otherwise, nine times out of ten, you are simply rediscovering a bug found/fixed 3 years ago.
TopPages
