interrupt not working on at90can
6 posts / 0 new
i'm trying to setup a timer of 10 msec using timer1.
i've tried everything, but the led will not go on or toggle.
what am i missing.
int void (main)
TCCR1A = 0x80;
TCCR1B = 0x0C;
OCR1AH = 0x9C;
OCR1AL = 0x3F;
TIMSK1 = (1<<OCIE1A);
// enable interrupts
sei();
while(1){
//main code which works!
interrupt routine
ISR (TIMER1_OVF_vect)
stap++;
uart_mini_printf ("-0- Interrupt reached ");
if(stap >50)
write_led_number (0,1); // statusled on 0,5 sec
if (stap >100){
write_led_number (0,0); // statusled off 0,5 sec
if (stap>150)stap=0;
i'm using avrstudio 6 and winavr.
and led works when used in main programm.
what am i doing wrong !
thanx in advance
You can start with this https://www.avrfreaks.net/index.p...
TCCR1A = 0x80;
TCCR1B = 0x0C;
OCR1AH = 0x9C;
OCR1AL = 0x3F;
using magic numbers makes following things confusing, use bit name as in
This CLEARLY tells people that you have enable the output compare 1A interrupt, the other stuff tells us nothing.
I don't see your declaration for stap. I'm guessing it's defined globally and not defined as volatile. If it's a local variable to the ISR, it needs to be defined as static.
Don
Stefan Ernst
Stefan got it I think, you are enabling the output compare interrupt but using the wrong vector (the overflow vector)
stupid of me, misread the datasheet!
thanks for your replays, i solved it.
this topic can be closed...
thanx again.
