No Debug Platforms available.
14 posts / 0 new
I just installed Studio 4 and when I try to load a file, the list of Debug Platforms is empty. This means all devices are greyed out and not selectable. I tried an uninstall and re-install to no avail. Any ideas how to get this to work?
I'm using XP Home.
This is the first time I have ever installed Studio.
thanks,
dave
You should have the simulator option. With it you should be able to use pretty much all of the chips.
I guess that is my problem. The window is completely empty. I don't even have the simulator option.
I have installed three times now, with reboots. I don't think it is making any difference :)
thanks,
Do I have to do anything special to see the simulator option?
I compiled my sample code "Blinky" into the coff format, opened it within Studio then it presented me an emply list of debug platforms, next to a greyed out list of parts.
I don't have a device hooked up to my computer at all. It is still in the box as I'm waiting for my programer to arrive. I was hoping to get a jump start on writing the program while waiting :)
thanks,
dave
Dave,
I've used the AVR Studio simlator on XP with no problems. I've outlined the steps in the guide that follows my signature. I'm hoping that it is a coincidence that your program is called Blinky and that you haven't already gotten the guide. If so I'll need to revisit the steps I've outlined.
Good Luck,
Smiley
Actually it is your guide that I followed :)
I skipped the "hardware" portion because I don't have the ISP hardware yet. I did get everything compiled with winAVR, and can load blinky.coff, but I cannot simulate it.
EDIT: Just is case this helps:
I get the following message in the Messages window:
Loaded partfile: c:\Program Files\Atmel\AVR Tools/PartDescriptionFiles\
I then have to hit cancel on the window becuase everything but the Help is greyed out.
I then get this:
Coordinator The debug platform module has not been created.
Error loading objectfile C:\WinAVR\Projects\Blinky\Blinky.cof
thanks,
Well,
I just installed an a differenct computer that I have. It is running XP Pro SP2 and it installs fine and works fine also. It appears that there is a problem with XP Home.
Anyone here installed on XP Home before?
thanks,
Yes. It's installed on XP Home on the computer I'm using right now. Debug started up as normal.
Dave,
If you haven't already done so, you might want to try downloading and installing MSXML 4.0 SP2 from this link.
Don
Don,
I tried that and it did not help.
This is quite frustrating. It works on my media server, but not my development system.
ARGS!
I'm using XP home edition with no problems. It is puzzling that you can get it working XP Pro but not home. Have you gotten all the updates?
Smiley
And reeboot in case You didn't. (Rant: Remember this is Windoze which is such a "stovepipe system" it requires a total reebot almost every time a system component is installed or updated).
I have the same problem with XP, I have blank device platform window , and I don't know what I should do. In win98 everythings work fine. Anybody helps us?
lovingHDTV wrote:
I just installed Studio 4 and when I try to load a file, the list of Debug Platforms is empty...
This is from Atmel's site:
Question:
I can not select any devices for debugging in AVRStudio. How can they be enabled?
Answer:
Some users can not select any devices for debugging, and/or the debug session will never start. Typical only the ATmega128 is available for selection when using ICE40/50 and the simulator. This is probably caused by some .dll files being damaged and/or having wrong versions. We have identified two actions that can help to solve these issues:
1) Make sure you have the latest Internet Explorer version 6 installed with the latest service pack.
2) Install the Microsoft XML Parser (MSXML) 3.0 Service Pack 4 or later (SP4). AVR Studio 4 uses the XML parser extensively. This package can be downloaded from the following site:
The Microsoft® XML Parser (MSXML) 3.0 SP4 http://www.microsoft.com/downloa...
HTH
-Crybaby
