Alternative device programming application to Studio 6
6 posts / 0 new
Is there an alternative software application for the pc to program hex code via the avrisp instead of having to install all of Studio6 ?
The device is the mega88.
I want to be able to give a hex file to a customer and get them to install a small piece of programmer software to connect to the boards I've made for them via the Avrisp so they can update the software.
Studio 6 is just a little cumbersome for them to do this.
Mark
markah
avrdude
pony
No RSTDISBL, no fun!
Also, this was just discussed here.
:: Morten
Respected Sir,
You did Ask this question few years ago. Did you get any alternative to burn hex code without using Atmel Studio .
Thank you,
Parth
Umesh mishra
Did you try any of the suggestions made?
