AVR ADC Multi Channel Input
5 posts / 0 new
I am a beginner in programming with AVR MCU and understand that setting ADMUX to values 0,1,2,3,4,5,6,7 will correspondingly enable ADC0,1,2,3,4,5,6, ADC7 AVR MCU ADC.
Hence :
ADMUX = 0b11000000; /* means ADC0 as Input and using Internal VRef*/
But if I want to use both ADC0 and ADC1 for input then what values in ADMUX I should set as 0b11000001 would mean ADC1 as input only. As such do I set in a loop values 0 and 1 in ADMUX and iterate?
Please let me know how can I select both ADC0 and ADC1 (more than one) ports for ADC input and read input value respectively.
What processor model ?, (they are not identical in operation.)
Do you want to do one differential conversion (ADC1 - ADC0) ? or two conversions ? (ADC0 then ADC1)
I am using CodeVision AVR for coding and Proteus for simulation. I am using ATMEGA 8535 MCU.
In actual I need to read two sensors values in-coming to ATMEGA 8535 ADC, hence I believe that I need two conversions i.e. what values each sensors are sending.
You need to read one channel and then the other. Only one channel of ADC in the AVRMega controllers. MUX is exactly what it saws, a mux that only selects the pin the ADC channel is going to be connected to at that point.
Thanks for the details. I would implement the same methodology.
