New Project Tool
5 posts / 0 new
When using AVRGCC with AvrStudio, it is quite some work before you can start with your real project.
You have to change the makefile and the projectsettings.
When you forget one of these changes, your project will not work, and it's hard to find what went wrong.
So I developed a program wich do the changes for you, so this can't go wrong anymore.
I send it with this post:
newproject.zip 9.90 kB
Sodownload it, try ,and add your comments!
janpieter
admin's test signature
zip file seems to be empty....
nuc134r m4n
I have the same problem sometimes using Winzip if you try to open a zip file directly from a link. If you save it first, then try to open it, you should see the contents.
Take care,
Mike H.
thanks. windows xp zip viewer did not work as well when i clicked on the link, but when i saved the file to my drive first, it worked. thats a strange behaviour!
nuc134r m4n
I have no experience with windows xp.
I used Winzip 8.0 to zip, and in Windows 98 it works fine.
But if Mike Henning is right, there's no problem anymore!
Jan Pieter
