simple Icall question
3 posts / 0 new
Hello:
I am trying to make a jump (to subroutines) using ICALL. I am assuming the corresponding return instruction is simply ret. is this true?
My code seems to lock up--if I kill the Icall all is well!! any thoughts?
ldi ZH, high(actions*2) ;get address of command check string
ldi ZL, low (actions*2)
mov temp, routine_to_do ;specify which subroutine to run
lsl temp ;mult by 2 to for word address
add ZL,temp ;point to table address (base +2*cmdnum)
clr temp
adc ZH,temp ;propogate carry
icall ;execute valid cmd subroutine
more code--seems to never come back here/locks up
routine0: ret ;right now routines do nothing but return
routine1: ret
actions: dw routine0, routine1
You are calculating the pointer to your table, of function addresses... but you are never loading the address in the table back into Z for ICALL to use. So instead you are jumping to an unexpected location in flash.
ICALL will interpret the address in Z as a word address, though when you execute ICALL, it holds the byte address of the entry in the function table you should be loading, so you are really jumping to (base + 2 * cmdnum)*2.
I usually create a rjmp table holding the actions addresses so ican use a byte pointer:
clr temp
more code
actions:
rjmp routine0
rjmp routine1
rjmp routine2
routine0: ret
routine1: ret
routine2: ret
