Peace be upon you. I have a problem in atmega32 uc
13 posts / 0 new
i have problem in uc atmega32
I can not remove internal clock
i use bascom avr
use very simple serial rs232 programer
at-prog for burn hex code
how can i remove internal osc crystal fuse bit ?
use this fuse calc to find out the values... We are not sure on what other settings you want.. so it is difficult to say the exact values.. http://www.engbedded.com/fusecalc
i use bascom avr
Do you have an external clock to use instead of the internal clock?
I want to remove internal clock
and use external crystal xt
i use this program to burn hex code
http://www.speedy-bl.com/avr-pro...
yes . i have alot of crystal 8mhz . 4mhz ....
or use RC OSC ...
That software does not seem to be able to program the AVR fuses. Thus, you can not use it to change from the internal clock source to anything else.
You need another programming software. And that, in turn, might require a different programming hardware.
OK . Thank you very much
i will made usbasp .
I want to help in another problem
i have lcd 16 x 2 and burn simple code to atm32
using bascom avr
program working very good in Proteus
but in practical not working .
Each wire is connected correctly..
but not working
Config Lcdpin = Pin , Db4 = Portc.3 , Db5 = Portc.2 , Db6 = Portc.1 , Db7 = Portc.0 , E = Portc.4 , Rs = Portc.5
Config Lcd = 16 * 2
Locate 1 , 1 : Lcd "eg_coder"
do
loop
end
Welcome to the Forum.
Did you make the PCB or is it a commercial board?
Does the PCB run other programs correctly?
Is this the first program you have ever run on this board?
Have you adjusted the contrast control to see if the text is actually there?
On start up do you see one row of "black boxes" on the LCD as the LCD initializes?
I don't have time to test the code but for right now try:
$regfile = "m32def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 10
$framesize = 40
Config LCD = 16 x 2
Config LCDpin = pin, ...
Initlcd
waitms 100
cls
lcd "Hello"
do
loop
If this is a new board, do you have by-pass caps, (0.1uF) on the Vcc/Ground pin and AVcc/ground pin?
Is AVcc tied to Vcc?
Turn off the jtag, which hogs up portc. You write MCUCR = 0x80 twice.
$crystal = 8000000
$hwstack = 32
$swstack = 10
$framesize = 40
Config LCD = 16 x 2
Initlcd
waitms 100
cls
lcd "Hello"
do
loop
Thanks for help
ok ...
This is not the first program
Made several experiments on the same board and the same uc (flasher led . 7seg count ...... )
working good
no.i dont use pcb
i use breadboard
yes i see one row "black boxes" on the LCD
when power on circuit
i test your code but not work
yes i use already capc 0.1uf and 10 uf
Parallel to vcc and gnd
i test lcd with pic uc pic16f84a
working good !!!
I do not know where the problem ØŸ
i serch youtube about jtag
http://www.youtube.com/watch?v=I...
how can i Turn off the jtag
by code or by programer ?
EDIT: Gave an answer but it was not for Bascom.
Mislead again by a previous poster. :? It will not happen again.
@eg_coder, see DocJC's post below.
Maybe the datasheet? [but that requires reading]
Maybe this site? [but that requires computer skills]
How'd the "video generation" approach work out for you?
Port C has several functions in the M32 chip.
The easiest was to disable (turn off) the JTAG function n Bascom is to use the instruction:
Disable JTAG
Put that at the start of the program.
Report back on how you are doing.
