"table"-datastructure in Flash-Memory
3 posts / 0 new
I just started to implement a simple datastructure to lookup values by a given key-value.
The datastructure doesn't have to be "hight-performance", the only requirement is that the data is in Flash-Memory (PGM).
( To keep it simple I started my first approach in RAM: )
so I startet defining the structure:
/** \brief Table-Entry Data-Structure */
typedef struct{
	uint8_t key;
	uint8_t value;
}table_entry;
/** \brief Table Data-Structure */
typedef struct{
	 uint8_t len;
	 table_entry *tab;
}table;
then I wrote a function to access the stored values by a key-value:
uint8_t *table_get_value(table *t, uint8_t key){
	uint8_t i=0;
	while( i<(t->len) ){
		if(t->tab[i].key==key) return &(t->tab[i].value);
		i++;
	return NULL;
initialized the data:
table_entry entries[5] = {
	{5,1},
	{4,2},
	{1,3},
	{2,4},
	{3,5}
table tab = {
	{5, entries}}
But all the time I query the pointer to the value of the key-value "1"
table_get_value(&tab, 1);
I get a NULL-Pointer in return. If I examine the tab data-structure with the "watch"-utility of atmel studio I can see that the pointer of "entries" in "tab" points to zero.
So i thought entries is not known at load time, when tab is initialized, but even
table tab = {
	{5, {{5,1},{4,2},{1,3},{2,4},{3,5}} }
results in the same way...
I googled for a lot of C-Examples to implement a hashtable in C. They had all one thing in common:
- to complicated for my purpose
- data-structure not initialized at load-time (what is necessary to port it to the flash-mem version afterwards)
So if anyone has a clue....
Greetings,
jabba
Not sure why you couldn't have just put all that into a complete test program and posted it here? Anyway I did:
#include
#include
typedef struct{
    uint8_t key;
    uint8_t value;
}table_entry;
typedef struct{
    uint8_t len;
    table_entry *tab;
}table;
    {5,1},
    {4,2},
    {1,3},
    {2,4},
    {3,5}
table tab = {
    5, entries
    uint8_t i = 0;
    while( i < (t->len) ){
        i++;
    return NULL;
int main(void) {
    PORTB = *(table_get_value(&tab, 1));
In the simulator that writes 3 to PORTB. That's exactly the value I would have expected so I'm not entirely sure what's wrong? (the 3 comes from the {1,3} entry in the table - the one with key value==1 which is what was asked for).
True I edited the code slightly to get rid of the warnings that came from your over-use of { }. I also added some white space around operators as I found it unreadable otherwise. But other than that this is your code and it works.
With the 4.7.x version of the compiler you now just need to added "__flash" and everything can easily be located into flash rather than the precious RAM where it currently resides in .data
Unbelievable!
This morning I ran the whole thing again and it just worked as intended. :D
Really don't know what's the difference to yesterday.
Anyway, thanks for your effort. I hope I will be able to return the favor some time.
Greetings,
jabba
