No SCKs on SPI?
5 posts / 0 new
I am trying to use the SPIC on PORTC on an xmega32a4u. I have the SPI channel configured as a master. To send data, I chip-select my slave device, write a data byte to the SPI.DATA register, and then wait for the SPI.STATUS register interrupt flag to set.
When I probe the SCK line during transfers, it only strobes high and low once as opposed to continuously pulsing. I have set up the xmega to utilize the internal 32MHz oscillator and have confirmed that the peripheral clock is running at the expected frequency.
Are there any other parameters I may have to configure to run the SPI properly?
Thanks.
Hmm. Doesn't sound quite right. When you put a byte out, the sck should go 8 times. Here's the code I use:
/* Defines needed to make this work
   Usually defined in Config.h
   #define SPIPort PORTC
   #define SPIMO   7
   #define SPIMI   6
   #define SPISC   5
   #define SPISS   4
uint8_t SPIDir = 0 ;
void spiopen(void)
	SPIDir = SPIPort.DIR ;
	SPIPort.DIRCLR = (1<<SPIMI);
	SPIPort.DIRSET = (1<<SPIMO) | (1<<SPISC) | (1<<SPISS) ; // Make sure slave select is an output
	SPIC.CTRL = SPI_ENABLE_bm | SPI_MASTER_bm | SPI_MODE_0_gc | SPI_PRESCALER_DIV64_gc;
void spiclose(void)
	SPIC.CTRL = 0;
	SPIPort.DIR = SPIDir ;
	//SPIPort.DIRSET = (1<<SPIMI);
uint8_t spi(uint8_t val)
	SPIC.DATA = val ;
	while(!(SPIC.STATUS & (1<<7)));
	return SPIC.DATA;
I use spiopen to prepare the port for spi, and spiclose to return the port to other uses because one device I used the 4 spi pins for other io too. Rather silly of me.
Without adult supervision.
Does the Xmega suffer from the same SPISS gotcha as the tiny/mega did?
(that is that if the SS pin is left floating and goes low the SPI switches from master to slave so writing the data register no longer triggers 8 SCKs)
It might! It might not show here, but be sure the SS pin is configured for an output.
Just ran into a similar problem tonight. I think Torby's code has the answer. You need to set both the clock and data pins as outputs via PORTC.DIRSET.
Don
