4 posts / 0 new
@Joerg
I tried to compile the complete AVR tool chain like explained in avr-libc manual using cygwin. Everything compiled without errors.
But two questions:
During configuring of avr-libc I saw some statements like this:
"checking if avr-gcc support AT90CAN128... no"
"checking if avr-gcc support ATmega6450... no"
and so on (for all newer devices).
Is it normal? Does it reduce the function of avr-libc?
Also the binutils doesn't work after compiling.
ie: "as.exe" stops with error:
"Prozedureeinsprungpunkt _impure_ptr wurde in DLL cygwin1.dll nicht gefunden."
"Procedure step in point _impure_ptr not found in DLL cygwin1.dll" (free translation :wink: )
Any ideas hat could be the problem?
You need a patched GCC in order to get support for the new devices.
All released version of GCC do not support them yet.
avr-libc's configuration script automatically adopts to the compiler's
capabilities here.
The CRT files (C run-time startup code) for the new devices can't be
built unless your compiler supports them. Other than this, no further
restrictions are applied.
That's a Cygwin problem, sorry, I can't help here.
If you set a
LANG=C
in your Cygwin shell before running the binary, you should get the
original English message for it. Please use this message to ask the
Cygwin people about it.
Jörg Wunsch
I think there should be a note about this issue in avr-libc manual and README or INSTALL. Found nothing so far.
But anyway, thanks for help. Was just a try, I will wait for a new WinAVR release then.
If you've got WinAVR anyway, you can always use the (patched) GCC that
ships with WinAVR itself to build the new library version.
You need a few pieces from Cygwin in order to build it, but not too
much.
Jörg Wunsch
