debugging/watching classes in AS6.1
4 posts / 0 new
It is the first time I use C++ for one of my projects.
Even more stupid, I tried to modify an existing (and more or less working) project and replaced parts of the code for use of a C++-class (code for circular buffer).
It took me almost one day to solve all compiling errors.
Now, the code compiles and should be debugged on a test circuit using an JTAGICE3.
Whenever the constructor-code for the class is reached, I can see, that all class-intern pointers remain 0000 (!) and other variables don't change their values.
Is there any problem known while debugging a class ?
I program like a man:
COPY CON: > firmware.hex
you can definitely debug classes using the simulator. I do not use a JTAGICE3 so cannot comment on its behaviour.
I suggest trying it with the studio simulator and validating that the code works as you expect and then moving to the ICE.
regards
Greg
With JTAGICE3 I have the strange effect, that sometimes being inside the class coe, anything is 0.
The correct values show up after exiting the class-code
Which AVR are you using?
AVR Clock speed?
The JTAG speed could be either too high or too low.
