'Code / Memory' size message missing .
2 posts / 0 new
Having suffered a dead HDD - I've reinstalled Studio 4.19 and WinAVR - thanks to Clawson for the 'how toget it to work' sticky.
But after Ive successfully built the code it no longer finishes with the size of memory details.
All I get is :
'Build succeeded with 12 Warnings...' and thats it.
I miss the code size details as I used to rely on it as a quick guide before continuing.
Any clues what's happened?
TIA
Rob
Yes. Atmel messed up in 4.19 and the memory report is not generated in that version of AVR Studio. No, it won't be fixed. AVR Studio 4 is dead, and not maintained anymore.
(Well, if you promise Atmel to buy 10 million AVRs the will bend over backwards, lick your feet and fix AS 4.19 - but if you where to buy 10 million AVRs you'd already know that.)
Just run avr-size yourself manually.
