Compiling with debug information into .elf file.
13 posts / 0 new
When I started working with AVR32:s and compiling I found that my .elf files were around 35 megs of data. I had a look a them and saw that my code was in the files in clear text. I back then (years back) found a setting that removed that information so that I could ship out .elf files to customers without showing my code in them.
I now have a problem with my code and would like to run it in debug mode on the hardware. But I cant since the debug information is not in the .elf file any more. How did I do to remove this debug information, how do I get i back?
Im using avrstudio 6 and programming an UC3A3.
Thanks for any assistance,
Anders
GCC’s option “-g” enables debugging information. Leave it out to get none. The GCC documentation is your friend.
If you compile your code with -g, use avr-strip on the .elf to get rid of all debugging information (and some other usually not that important stuff). If you use avr-strip, make sure that your program still flashes and runs correctly.
I am using -g, and the elf file grows from 66 kB to 79kB, nowhere near the 34 750kB earlier. And the debugging in Studio6 only shows assembler code when pausing.
Show complete build output (compilation, linking).
------ Build started: Project: AGM2 - Software, Configuration: Release AVR ------
Build started.
Project "AGM2 - Software.cproj" (default targets):
Target "PreBuildEvent" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Avr.common.targets" from project "C:\AGMProject\Atmel\AGM2 - Software\AGM2 - Software.cproj" (target "Build" depends on it):
	Task "Exec"
		Command:
		del "C:\AGMProject\Atmel\AGM2 - Software\Release\src\messageHandler.o"
	Done executing task "Exec".
Done building target "PreBuildEvent" in project "AGM2 - Software.cproj".
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Compiler.targets" from project "C:\AGMProject\Atmel\AGM2 - Software\AGM2 - Software.cproj" (target "Build" depends on it):
	Task "RunCompilerTask"
		C:\Program Files (x86)\Atmel\AVR Studio 5.1\make\make.exe all
messageHandler.c
		Invoking: AVR32/GNU C Compiler
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/HOST" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU"  -O3 -fdata-sections -ffunction-sections -masm-addr-pseudos -pg -p -Wall -c -c -fmessage-length=0 -MD -MP -MF "src/messageHandler.d" -MT"src/messageHandler.d"  -mpart=uc3a3256  -o"src/messageHandler.o" "../src/messageHandler.c"
C:\AGMProject\Atmel\AGM2 - Software\src\messageHandler.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		../src/messageHandler.c: In function 'handleMessage':
C:\AGMProject\Atmel\AGM2 - Software\src\messageHandler.c(250,1): implicit declaration of function 'getTrigOnImaging'
C:\AGMProject\Atmel\AGM2 - Software\src\messageHandler.c(1748,1): implicit declaration of function 'clearAdcTimeout'
C:\AGMProject\Atmel\AGM2 - Software\src\messageHandler.c(1753,1): implicit declaration of function 'adcHasTimeouted'
		Finished building: ../src/messageHandler.c
adc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/HOST" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU"  -O3 -fdata-sections -ffunction-sections -masm-addr-pseudos -pg -p -Wall -c -c -fmessage-length=0 -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.c"
C:\AGMProject\Atmel\AGM2 - Software\src\SOFTWARE_FRAMEWORK\DRIVERS\ADC\adc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.c
		Building target: AGM2-Software.elf
		Invoking: AVR32/GNU C Linker
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe" -o AGM2-Software.elf  src/imageSample.o src/LIS331DLH.o src/main.o src/MAX5136.o src/messageHandler.o src/realTime.o src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.o src/SPI_resources.o src/surveillance.o src/SOFTWARE_FRAMEWORK/ASM/trampoline.o src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.o src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.o src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.o src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.o src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.o src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.o src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.o src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.o src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.o src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.o src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.o src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.o   -nostartfiles -s -Wl,-Map="AGM2-Software.map" -lnewlib_addons-at32ucr2-speed_opt -lm  -L"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS" -L"../src/SOFTWARE_FRAMEWORK/BOARDS"  -Wl,--gc-sections --rodata-writable -Wl,--direct-data -Wl,--gc-sections -Wl,-e,_trampoline -T../src/SOFTWARE_FRAMEWORK/UTILS/LINKER_SCRIPTS/AT32UC3A3/256/GCC/link_uc3a3256.lds  -mpart=uc3a3256
		Finished building target: AGM2-Software.elf
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature  "AGM2-Software.elf" "AGM2-Software.hex"
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "AGM2-Software.elf" "AGM2-Software.eep" || exit 0
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objdump.exe" -h -S "AGM2-Software.elf" > "AGM2-Software.lss"
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-size.exe" "AGM2-Software.elf"
		   text	   data	    bss	    dec	    hex	filename
		  58168	   5309	  60583	 124060	  1e49c	AGM2-Software.elf
	Done executing task "RunCompilerTask".
Done building target "CoreBuild" in project "AGM2 - Software.cproj".
Target "PostBuildEvent" skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as ('' != '').
Target "Build" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Avr.common.targets" from project "C:\AGMProject\Atmel\AGM2 - Software\AGM2 - Software.cproj" (entry point):
Done building target "Build" in project "AGM2 - Software.cproj".
Done building project "AGM2 - Software.cproj".
Build succeeded.
========== Build: 1 succeeded or up-to-date, 0 failed, 0 skipped ==========
Is that everything? Its all I get when I compile.
I am using -g
I see no -g option at all in the build output you supplied.
In the software properties under Toolchain - AVR32/GNU Preprocessing Assembler - General I have -Wa,-g. All other options under Toolchain is set to maximum debugging (-g3).
Perhaps I need to recompile all files?
Whatever, but if I look at the command actually executed, e.g. the firs tcompilation command
messageHandler.c
there is no -g option. Period.
Some things from your settings dislogs are not getting through to the actual build, or you missed a setting somewhere.
When I recompile all files I get -g3 and -g in a whole bunch of places. Still no information in the debugging.
When I start debugging and klick pause-button, Call stack shows an arrow and sais "AGM2-Software.elf! no-debug-info".
Not in the build output you have shown - which is here for all to see in this thread. You either posted some bogus build output, or you are seeing things that are not there.
Anyway, my wish for a build output was because that is the telltale witness on whether a compiler option is actually activated. Your reply is a build output which show they are not there, but you also say "I see them when I build". This makes no sense to me. Meaningless ativity. I'm out.
------ Rebuild All started: Project: AGM2 - Software, Configuration: Debug AVR ------
Build started.
Project "AGM2 - Software.cproj" (ReBuild target(s)):
Target "PreBuildEvent" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Avr.common.targets" from project "C:\AGMProject\Atmel\AGM2 - Software - Studio6\AGM2 - Software.cproj" (target "ReBuild" depends on it):
	Using "Exec" task from assembly "Microsoft.Build.Tasks, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
	Task "Exec"
		Command:
		del "C:\AGMProject\Atmel\AGM2 - Software - Studio6\Debug\src\messageHandler.o"
Target "CoreRebuild" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Compiler.targets" from project "C:\AGMProject\Atmel\AGM2 - Software - Studio6\AGM2 - Software.cproj" (target "ReBuild" depends on it):
	Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Compiler.Task.dll".
		C:\Program Files (x86)\Atmel\AVR Studio 5.1\make\make.exe clean all
		rm -rf  src/imageSample.o src/LIS331DLH.o src/main.o src/MAX5136.o src/messageHandler.o src/realTime.o src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.o src/SPI_resources.o src/surveillance.o src/SOFTWARE_FRAMEWORK/ASM/trampoline.o src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.o src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.o src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.o src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.o src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.o src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.o src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.o src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.o src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.o src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.o src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.o src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.o src/imageSample.d src/LIS331DLH.d src/main.d src/MAX5136.d src/messageHandler.d src/realTime.d src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.d src/SPI_resources.d src/surveillance.d src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.d src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.d src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.d src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.d src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.d src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.d src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.d src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.d src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.d src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.d src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.d src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.d src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.d src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.d src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.d src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.d src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.d
		rm -rf "AGM2-Software.hex" "AGM2-Software.lss" "AGM2-Software.eep" "AGM2-Software.map"
imageSample.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/imageSample.d" -MT"src/imageSample.d"  -mpart=uc3a3256  -o"src/imageSample.o" "../src/imageSample.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\imageSample.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/imageSample.c
LIS331DLH.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/LIS331DLH.d" -MT"src/LIS331DLH.d"  -mpart=uc3a3256  -o"src/LIS331DLH.o" "../src/LIS331DLH.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\LIS331DLH.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/LIS331DLH.c
main.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/main.d" -MT"src/main.d"  -mpart=uc3a3256  -o"src/main.o" "../src/main.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\main.c(1,1): -ffunction-sections disabled; it makes profiling impossible
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\main.c(37,1): 'init_hmatrix' defined but not used
		Finished building: ../src/main.c
MAX5136.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/MAX5136.d" -MT"src/MAX5136.d"  -mpart=uc3a3256  -o"src/MAX5136.o" "../src/MAX5136.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\MAX5136.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/MAX5136.c
messageHandler.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/messageHandler.d" -MT"src/messageHandler.d"  -mpart=uc3a3256  -o"src/messageHandler.o" "../src/messageHandler.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\messageHandler.c(1,1): -ffunction-sections disabled; it makes profiling impossible
realTime.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/realTime.d" -MT"src/realTime.d"  -mpart=uc3a3256  -o"src/realTime.o" "../src/realTime.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\realTime.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/realTime.c
led.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.d" -MT"src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.o" "../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\BOARDS\AGM_Board_D\led.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.c
SPI_resources.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SPI_resources.d" -MT"src/SPI_resources.d"  -mpart=uc3a3256  -o"src/SPI_resources.o" "../src/SPI_resources.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SPI_resources.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SPI_resources.c
surveillance.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/surveillance.d" -MT"src/surveillance.d"  -mpart=uc3a3256  -o"src/surveillance.o" "../src/surveillance.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\surveillance.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/surveillance.c
trampoline.x
		Invoking: AVR32/GNU C Preprocessing Assembler
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe" -x assembler-with-cpp -c -Wa,-g -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I "../../AGM - Software/src/CONFIG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/BOARDS" -I "../../AGM - Software/src"  -g3  -mpart=uc3a3256   -o"src/SOFTWARE_FRAMEWORK/ASM/trampoline.o" "../src/SOFTWARE_FRAMEWORK/ASM/trampoline.x"
		Finished building: ../src/SOFTWARE_FRAMEWORK/ASM/trampoline.x
adc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\ADC\adc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
smc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\EBI\SMC\smc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.c
flashc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\FLASHC\flashc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.c
gpio.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\GPIO\gpio.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.c
exception.x
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe" -x assembler-with-cpp -c -Wa,-g -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I "../../AGM - Software/src/CONFIG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/BOARDS" -I "../../AGM - Software/src"  -g3  -mpart=uc3a3256   -o"src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.x"
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.x
intc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\INTC\intc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.c
pdca.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\PDCA\pdca.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.c
pm.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\PM\pm.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.c
pm_conf_clocks.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\PM\pm_conf_clocks.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.c
power_clocks_lib.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\PM\power_clocks_lib.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.c
rtc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\RTC\rtc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.c
spi.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\SPI\spi.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.c
tc.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\TC\tc.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.c
usart.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USART\usart.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.c
usb_drv.c
		Invoking: AVR32/GNU C Compiler
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\usb_drv.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.c
usb_task.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\usb_task.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.c
usb_descriptors.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\DEVICE\usb_descriptors.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.c
usb_device_task.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\DEVICE\usb_device_task.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.c
usb_specific_request.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\DEVICE\usb_specific_request.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.c
usb_standard_request.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\DEVICE\usb_standard_request.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.c: In function 'usb_set_configuration':
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\USBB\ENUM\DEVICE\usb_standard_request.c(227,1): implicit declaration of function 'usb_set_configuration_action'
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.c
wdt.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.d" -MT"src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.o" "../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\DRIVERS\WDT\wdt.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.c
device_cdc_task.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.d" -MT"src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.o" "../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\SERVICES\USB\CLASS\CDC\device_cdc_task.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.c
debug.c
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe"  -DBOARD=AGM_D  -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I"../src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I"../src/SOFTWARE_FRAMEWORK/ASM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA" -I"../src/SOFTWARE_FRAMEWORK/UTILS" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/MEMORY/SDRAM/MT48LC16M16A2TG7E" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/CUST/XC225" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I"../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I"../src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I"../src/CONFIG" -I"../src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I"../src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I"../src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I"../src/SOFTWARE_FRAMEWORK/BOARDS" -I"../src" -I"../src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D"  -O0 -fdata-sections -ffunction-sections -mfast-float -ffast-math -masm-addr-pseudos -g3 -g -pg -p -Wall -c -c -fmessage-length=0 -g -MD -MP -MF "src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.d" -MT"src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.d"  -mpart=uc3a3256  -o"src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.o" "../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.c"
C:\AGMProject\Atmel\AGM2 - Software - Studio6\src\SOFTWARE_FRAMEWORK\UTILS\DEBUG\debug.c(1,1): -ffunction-sections disabled; it makes profiling impossible
		Finished building: ../src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.c
crt0.x
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe" -x assembler-with-cpp -c -Wa,-g -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/CPU/CYCLE_COUNTER" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/WDT" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/RTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/TC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/ADC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/SPI" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/DEBUG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/SERVICES/USB" -I "../../AGM - Software/src/CONFIG" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/COMPONENTS/JOYSTICK/SKRHABE010" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USBB" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/USART" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/PM" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/PREPROCESSOR" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/DRIVERS/INTC" -I "../../AGM - Software/src/SOFTWARE_FRAMEWORK/BOARDS" -I "../../AGM - Software/src"  -g3  -mpart=uc3a3256   -o"src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.o" "../src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.x"
		Finished building: ../src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.x
		Building target: AGM2-Software.elf
		Invoking: AVR32/GNU C Linker
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-gcc.exe" -o AGM2-Software.elf  src/imageSample.o src/LIS331DLH.o src/main.o src/MAX5136.o src/messageHandler.o src/realTime.o src/SOFTWARE_FRAMEWORK/BOARDS/AGM_Board_D/led.o src/SPI_resources.o src/surveillance.o src/SOFTWARE_FRAMEWORK/ASM/trampoline.o src/SOFTWARE_FRAMEWORK/DRIVERS/ADC/adc.o src/SOFTWARE_FRAMEWORK/DRIVERS/EBI/SMC/smc.o src/SOFTWARE_FRAMEWORK/DRIVERS/FLASHC/flashc.o src/SOFTWARE_FRAMEWORK/DRIVERS/GPIO/gpio.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/exception.o src/SOFTWARE_FRAMEWORK/DRIVERS/INTC/intc.o src/SOFTWARE_FRAMEWORK/DRIVERS/PDCA/pdca.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/pm_conf_clocks.o src/SOFTWARE_FRAMEWORK/DRIVERS/PM/power_clocks_lib.o src/SOFTWARE_FRAMEWORK/DRIVERS/RTC/rtc.o src/SOFTWARE_FRAMEWORK/DRIVERS/SPI/spi.o src/SOFTWARE_FRAMEWORK/DRIVERS/TC/tc.o src/SOFTWARE_FRAMEWORK/DRIVERS/USART/usart.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/usb_drv.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/usb_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_descriptors.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_device_task.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_specific_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/USBB/ENUM/DEVICE/usb_standard_request.o src/SOFTWARE_FRAMEWORK/DRIVERS/WDT/wdt.o src/SOFTWARE_FRAMEWORK/SERVICES/USB/CLASS/CDC/device_cdc_task.o src/SOFTWARE_FRAMEWORK/UTILS/DEBUG/debug.o src/SOFTWARE_FRAMEWORK/UTILS/STARTUP_FILES/GCC/crt0.o   -nostartfiles -s -Wl,-Map="AGM2-Software.map" -lm  -L"../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS/INCLUDE" -L"../../AGM - Software/src/SOFTWARE_FRAMEWORK/UTILS/LIBS/NEWLIB_ADDONS"  -Wl,--gc-sections -mfast-float -ffast-math --rodata-writable -Wl,--direct-data -Wl,--gc-sections -Wl,-e,_trampoline -T../src/SOFTWARE_FRAMEWORK/UTILS/LINKER_SCRIPTS/AT32UC3A3/256/GCC/link_uc3a3256.lds  -mpart=uc3a3256
		Finished building target: AGM2-Software.elf
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature  "AGM2-Software.elf" "AGM2-Software.hex"
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "AGM2-Software.elf" "AGM2-Software.eep" || exit 0
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-objdump.exe" -h -S "AGM2-Software.elf" > "AGM2-Software.lss"
		"C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain\bin\avr32-size.exe" "AGM2-Software.elf"
		   text	   data	    bss	    dec	    hex	filename
		  71276	   5316	  60584	 137176	  217d8	AGM2-Software.elf
	Done executing task "RunCompilerTask".
Done building target "CoreRebuild" in project "AGM2 - Software.cproj".
Target "PostBuildEvent" skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as ('' != '').
Target "ReBuild" in file "C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Avr.common.targets" from project "C:\AGMProject\Atmel\AGM2 - Software - Studio6\AGM2 - Software.cproj" (entry point):
Done building target "ReBuild" in project "AGM2 - Software.cproj".
Done building project "AGM2 - Software.cproj".
Build succeeded.
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
