AVRASM2 wish list
3 posts / 0 new
Hi All - or rather Atmel!
I've just installed Studio-v4.10; which contains avrasm2-beta. Here is my feedback (or my 'wish list') regarding the new assambler.
Macros, apart from '.set' directive, should also accept '.equ' and '.org' directives. In my programming practice, I find the following macros usefull and enhancing the code readibility. Of cource others may find other usefull ways of using those - the fact, that macro might create named value tat is 'update protected' (like '.euq') is atreative for a programmer. I fail to see a reason to keep this feature away.
.macro function
        .cseg
global @0:
.endm
.macro interrupt
        .cseg
@0_here:
        .org    @0addr
        jmp     @0_here
        .org    @0_here
.endm
; Then I write:
        .dseg
test:        .byte      3
function getc
; something
        ret
interrupt URXC0
; something else
       reti
This way I can have the interupt routine listed (and confined) within my sources where it's (textually) most relevant, while making sure, that a correct interupt vector will be generated by the assambler. This wasn't possible with avrasm nor it is possible with avrasm2. Pity.
As a side note. May be there should be a 'sticky' topic on this list. Like: "Top-10 most desired feratures", where such 'wish-list' would be maintained (and may be voted)?
-R
OT:
You can make the topic sticky yourself. And, you can also create a survey (that can be voted on) too.
It is a bit late now to make changes like this for the next upcoming release of the assembler, but I have noted your suggestions for possible consideration for a later AVRASM2 version (possibly in modified form using the preprocessor).
Sounds like an interesting idea.
Roland Kruse
Atmel AVR Tools
Please don't report bugs in private forum messages.
Roland Kruse
Atmel AVR Tools
