xMega USART: Which pins?
4 posts / 0 new
On the E5 chips, the USARTC0 can be on PORT C pins PC1, PC2 and PC3; or on PC5, PC6 and PC7. Where do you select which? I want to use PC1, PC2 and PC3. DOC8049 seems a little brief.
Unless you set a bit to move it the chip will default to the lower pins.
The lower port pins are default as John say. If you want the upper pins you set a bit in the PORTC.REMAP register. See 12.13.13 in the Xmega E manual.
Cool. Thanks.
